Question about Insignia IS-LCDTV32 32 in. Television
Display window stays on screen, buttons won't work
Yesterday i turned on my tele and the diplay window that shows what channel is being viewed won't go away and none of the buttons on the side will work except for the power button. Also the remote only works once in a million trys.
  • 51 Answers
Sounds like one of the buttons on the monitor is stuck in. See if you can unstick them by pressing them infirmly, but not too hard, several times. Try each one in succession. Hope this helps!
Posted on Jan 03, 2009
The touch screen of my Bernina 580 stopped working today and it was perfectly OK yesterday. Is there a way to fix it on my own or should I look for help?
Calibrate the diplay
The Display calibration can be opened as follows:
- turn off the sewing-/embroidery computer
- touch the two needle positioning buttons on the front panel and keep them pressed
- turn on the sewing-/embroidery computer and release the buttons as soon as the Display appears
- touch the calibration icon
- touch the center of the cross using the touch pen
-- the cross moves to the next position
- repeat this until all three positions shown are calibrated
-- the Display is closed
-- the adjustment is saved
Apr 13, 2014 | Bernina Artista 180
I have one of the old big screen tvs the hitachi rear view screen projector tvs I am trying to find a universal remote that would work perfect on it as we bought it from someone and didn't have a...
Generally universal remote controls won't work for all functions to any TV like its original remote do. Some functions may not differ, that is, if you try to up the volume, the tV's volume will go down, and so on. The most we can do is to try with other setup codes for the tV brand with the remote control, and synchronize it, check the functions, and accept a code which will give you most of TV's functions alright. I hereby attaches setup codes for Hitachi brand TV' both 3 digit and 4 digits. Try them, and see which code suits to your TV the most.
Three digit codes for Hitachi are: 001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are: 0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 22, 2012 | Televison & Video
Ctr display
Check to make sure all your color and tele wires are pluged in, turn on your playstation and check every channel til it shows your game
Aug 31, 2012 | Sony Crash Team Racing for PlayStation 1
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
MY SCREEN IS BLANK MY TV IS NON HDMI AND SO WAS
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Blank View Screen
Press DISP. button, and repeat untill the display shows up
Jun 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
78 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
