Question about LG 42LC2D 42 in. LCD HDTV
Xbox 360 Invalid Format
Hello, one day my T.V just would not have any display in both AV / HDTV mode on my Xbox 360 I can hear the sound in the background. It says "Invalid Format" I believe the problem is the display setting or something, but how am I to fix the problem if I can't see what I'm doing. Can anyone help please?
Thanks for your time.
  • 2 more comments
  • Anonymous Mar 20, 2009
    exact same thing, i was in the middle of playing a game and the screen went blank. it now says invalid format. i tried switching to AV but it's black aswell...i have a 46 in Bravia S series
  • Anonymous Apr 27, 2009
    Same, blank screen, can not find a fix any where, I am starting to get annoyed.
    I was playing, my screen went all weird red, then BOOM black, INVALID FORMAT
  • amedward May 03, 2009
    Red Blur s;ash across the screen,
    I replaced my wires
    IT FIXED THE PROBLEM
    now a week later, I am back where I started...
    HELP US
    Same red blur
    new wires fixed my problem, for a week
5 Suggested Answers
  • 10 Answers
SOURCE: INVALID FORMAT
the tv must see an input connected. try turning on the game before the tv.
Posted on Jan 08, 2009
  • 211 Answers
SOURCE: xbox 360 when hooked up to LG 42inch LC7D has sound, no picture
Please take a look at your Xbox menusettings, there could be the problem.
Kind regards,
Gerard
Posted on Jan 28, 2009
  • 57 Answers
SOURCE: invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
Posted on May 20, 2009
  • 58 Answers
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Posted on Sep 25, 2009
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Can hear the sound of the game but can't see the picture on Tv
try seeing if you have the cord connecting from your xbox to your tv is on regular tv instead of hdtv i had the same problem.
Dec 21, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 when hooked up to LG 42inch LC7D has sound, no picture
Kind regards,
Gerard
Jan 25, 2009 | LG 42LC2D 42 in. LCD HDTV
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Xbox 360
On your AV cord theres a switch that changes it from HDTV, to TV
Make sure its switched to TV if your not using HDTV, or switched to HDTV if ur using that. If you need pics let me know I can get you some so you can see where the switch is.
If that doesn't resolve it check your cords, make sure the cords match the colors.
Oct 17, 2007 | Microsoft Xbox 360 Console
No HDTV
Hi there. There might be some solution out there that would work for you, KboxMod. Here it is : To reset the display settings of the Xbox 360 console to the default settings, remove any discs from the disc tray. Turn the console off and turn it back on. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console. Note: If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated. Try it a few times, some say it took a few retries to get it working. It might just need a reset of those video settings. Hope that helps, cheebster.
Jun 05, 2007 | Microsoft Xbox 360 Console
LG 42LC2D 42 in. LCD HDTV Logo
1,289 people viewed this question
Computer Repairing
Computer Repairing
