Question about Casio Exilim EX-Z120 Digital Camera
Power Up Problem
Hi - I recently purchased a 1gb sandisk sd card for my casio ex-7120. I immediately began experiencing problems with starting my camera. When I press the on button the lens opens up but nothing appears on the lcd screen. After about 30 seconds the camera shuts itself down. If I then again attempt to turn the camera on it starts no problem. I can then take pictures no problem which save to the sd card. This is proving to be a nuisance as by the time I have managed to start the camera up I have often missed the photo opportunity. I have discovered a quick remedy although not favourable by which I remove the sd card and immediately reload it after the first start up fail. This then cuts out the 30 second delay waiting for the camera to shut itself down. I'd really appreciate some thoughts. Thanks Darren (UK)
  • Anonymous Feb 23, 2008
    Casio Exilim EX-Z850 locks up for 30 seconds after a photo, just started doing this. I have reviewed the manual but cannot figure out what I did. Thanks, John McGraw
OK, just got it back after the third try with Casio and they said it's fine--but it isn't. Same problem, no repair. They did not try testing the problem as described by both of us above; instead they just tested a bunch of different SD cards, one after the other, without waiting--which is when the problem occurs. They suggested using a smaller capacity SD Card, but you can see by the above that the 1GB card didn't work either. I'm going to give them another try, and hope that they just replace the camera after spending way too much time on this. I just want to shoot pictures. JT (USA--a Yank but not a Wank)
Posted on May 23, 2007
I almost thought I wrote that myself, except that it's signed Darren (UK). John (US)--that's me--had the exact same problem. I bought my z120 as a factory refurbished, didn't hesitate to send it into Casio Repair, and it came back twice, not fixed though they tried repairing the circuit board on the first try, and replacing the circuit board and firmware on the second try. I hear the standard policy is for them to replace the camera on the third try, which I just sent it back in for (and the person on the phone said the third round replacement is the standard). Note that even though my camera was factory refurbished, and bought on Amazon from someplace in California, Casio did not hesitate to honor the warranty and I did not have to go through the seller to get this done. I've been sending it to Casio Repair directly. Anyway, glad to know I'm not completely bonkers--even though I'm a Yank. Cheers! John (US)
Posted on May 14, 2007
SOURCE:
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Formatted a 2GB sandisk card in my camera. Lost
If you have an sd slot in your computer you can plug the card into sd slot start/computer/right click removable hard drive disk for sd card format
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
Camera Memory Card Capacity
Hi there, and welcome to FixYa.
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
Rob
Mar 02, 2009 | Casio Exilim EX-Z750 Digital Camera
Locked SD card
There should be a switch on the left side of the adapter just reverse it.
Jan 19, 2009 | SanDisk 1GB microSD Memory Card
Casio eXLIM
 I did have the same problem when I purchased the Casio EX-Z1000. This was when the camera was first released and purchased for £384. Was very upset when took photo's for a 21st birthday. The shop replaced the camera as it was with in a month of failing. The problem did not go and the only thing that wasn't replaced was the SD card. The SD card was purchased in Hong Kong and was maybe not reliable. I replaced with San Disk extreme III 2gb and works as dream. I purchased my SD from play.com. I must mention that I purchased a Cardrecovery.com application from the internet at $29 and this program has recovered all the missing photos.
Oct 11, 2008 | Casio EXILIM Card EX-S770 Digital Camera
2GB memory card but only 1GB available
That is one of the problems we have seen because it isn't a model that casio recommends using with the camera. Toshiba, Panasonic, and Sandisc are the only models that they have tested and know work so that's what they recommend you use.
Sep 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Micro SD NOT WORKING (SONY ERICSSON W580i)
You need to buy a different kind. i just bought a 4G Microcenter brand and its doing the same thing.
i'd recommend a Sandisk M-2 microSD.
Apr 12, 2008 | Sony Ericsson W850i Cellular Phone
Card error on my memory card
i have sold kingston sandisk and pny cards for years-sandisk excellent pny fine kingston is ****-made by pny but just not the same-switch card out asap and change brands-cards are slow and unreliable
Nov 20, 2007 | Casio Exilim Card EX-S100 Digital Camera
Casio Exilim EX-Z120 Digital Camera Logo
75 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
