Question about IBM eServer xSeries 206
No display and not functioning
I formatted hard drive.Then i wrongly selected the option boot with hard disk.afterthat whenever i switched on,there is no display and not responding the keys and not functioned.any suggestions plz..
WRONG......START UP SYSTEM THEN F8,,,SELECT VIDEO MODE...BAM DONE
Posted on Nov 26, 2011
I suggest that you clear hard drive and reformat it,again.Most of the time,booting from a floppy or optical drive,does the job satisfatorilly.I will suggest leaving your BIOS settings in their default state and make your adjustments when everything is up and running. from:justIT
Posted on May 11, 2007
Tip
How to format the hard disk ? here are the ways
what is hard disk? hardisk is an internal storage device by which we can store the data and also get back the data when we needed. hardisk is like a grama phone. you can create a partition on it also. so here are some tips how to format your hard disk. 1) plug in your hardisk by a external cable and wait for while to install the drivers . and then just double click on my computer and right click on the drive letter which you want to format and then hit format. now you have a option there select ntfs and defail and you have one more option called perfome quick format . if you click on this the formating will done quickly . and then start. done. <br /> 2) right click on my computer goto manage goto disk management and there you can see the drive letter just right click on it and format it . you can also remove the partion or create partion from there. <br /> 3) insert the xp boot disk and follow the instrucktion and after that you will get an option to select drive . just click on it and hit format . you have two types of formating ( quick) and full. <br /> 4) insert the win98 boot disk or insert hiren's boot disk and then go to dos ( for hiren boot disk only) after you completly boot from cd rom then you have an A:\ drive . this is called RAM drive. just write the command FDISK and hit enter and then Y and hit enter and then 4 to display partion. you can create a new partion from here also. after making any kind of changes you have to restart the pc . after restarting A:\ will appear. write down the command FORMAT C:\ and hit enter and Y thats it. <br /> there are many ways to format your drives. there are lots software also available in the market to format it. but the best way is 4) because it do the slow formating and also recover the allocation unit.
on Apr 25, 2011 | Computers & Internet
Laptop came with windows 7 factory installed on it. A friend accidently formatted the hard drive.
Either download an installer disk on to a DVD or partition a harddrive with an installer disk on it. Boot from that disk and restart the computer, it should boot up and ask to install Windows 7.
Dec 01, 2013 | HP Computers & Internet
Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
You also need to make sure the SATA cable is plugged into the right place on the board.
SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
If this is an addon drive then
Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  • I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    My laptop does not recognize my iomega hard drive
    You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
    I'm going to assume that you are using Mac OS X 10.5 or later.
    1. Open Disk Utility
    2. Select Applications > Utilities > Disk Utility
    3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
    ********Make sure you click on the high level icon, not the second level volume icon.********
    4. Select the Partition tab.
    5. Change Volume Scheme from Current to 1 Partition.
    6. Select the format type from the Format drop-down menu.
    Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
    7. Click on the Options button.
    8. Select the type of partition you want to use:
    GUID Partition Table - for boot ability on Intel-based Macs
    Apple Partition Map - for boot ability on PowerPC-based Macs
    Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
    CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
    9. Click OK.
    10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
    Dec 17, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
    I just purchased an iomega ego /500gb and I'm having a problem formatting it by following their instructions. I just want to be able to plug it in and save my music. My mac doesn't even recognize it once...
    You will need to format the drive to work with you Mac.
    3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon.
    NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
    9. Click OK.
    Nov 21, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
    How can i reformat my laptop?
    1. First format all the other partitions in your system except the Drive in which the OS is installed.
    2. Most probably the OS drive is C: Drive.
    3. Then get an operating system CD/DVD Windows XP/Windows Vista/Windows 7
    4. Then on start up insert the OS cd and select the option to install the OS.
    5. When you click next there will be an option to specify the Drive in which you will be installing the OS.
    6. Select the Drive in which the previous OS had been installed.
    7. Now in the next stage there will be option whether to install the OS with or without formatting Drive.
    8. Select the Format Drive Option and click Next.
    9. Congratulations you have formatted all the partitions in your System/Laptop/PC
    Apr 05, 2010 | Computers & Internet
    FORMAT hard disk with PEN DRIVE
    First you need to have the system files to format the harddrive and the process is to simply right click the pen drive and say Format . An option pops up select copy system files and format.then boot the system and it boots via pen drive type in the prompt Format c: /s/Q the disk will get formated.
    Regards.
    Feb 08, 2010 | Computers & Internet
    How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
    Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
    Jan 05, 2010 | Sony VAIO Notebook
    I can not install Windows on my Compaq Evo N620c
    The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
    May 04, 2009 | Compaq Evo N610C Notebook
    IBM eServer xSeries 206 Logo
    201 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Steve Allison
    Steve Allison
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
