Question about Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only
Porter cable beffer
Pad/backing plate won't begin spinning without spinning by hand to start.
  • David Ford
    David Ford May 11, 2010
    Can you provide the model number. But you can check on your own, does the motor run if yes then the backing plate can you turn it by hand easily or it tight? Let me know and I will pull up a schematic and see if I can help
  • 32 Answers
Check for string or build ups where the spindle come out of the housing, a little light oil at that point will help, 3-in 0ne is good, not to much, a little goes a long way
Posted on Jul 18, 2009
Porter cable model 333 will not orbit and spins at a very high speed. I do not have a manual.
there is a belt from the motor to the pad that has apparently broken. Go to and you can download both the parts breakdown and the operators manual. If I have helped you would you please vote accordingly and thank you
Sep 06, 2011 | Porter Cable 332K Quicksand Random Orbit...
I have a pts4 porter cable pneumatic sander that spins but stops on contact with a 100 grit pad or any pad that ive tried and this hapens even at the start before the compressor even kicks on. it didnt...
this unit takes 90 pounds per constant for desired function. Most machine shops have Huge compressors that will run these at a constant rate ,, also check the exhaust ( towards the vacuum hookup to check for clogs,, ) compressors that have a gauge that read 90 lbs doesn't necesarly mean they have the CFM to keep the pressure at what you need to keep it running
May 03, 2011 | Porter Cable PTS4 5 Inch Vacuum Ready...
My Porter Cable 4" Belt
I would check both rollers for debris on them, also check the plate on the bottom for unusual wear, be careful for sharp edges and make sure the front of the plate is not worn excessively. Then I would turn the front roller without the belt on it to make sure not out of round and moving smoothly. Lastly if you are using directional belts make sure installed properly with the arrow pointing to the front of the sander. Let me know if you need more help before voting and I will see what I can do.
Feb 13, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Need copy of owners manual. this is for type 1,,,if you need a different type then go to in the middle is a section titled "need a manual?" just enter in your model number and it should pull it up or if you don't know off hand then enter 557 and it will bring them all up for type 1 through 4
Jun 13, 2010 | Porter Cable - Cable 557 Factory -...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
I have a porter cable 5" r.o.s. that is not orbiting. what is the most common resolution to this problem?
It could be the bearing in the eccentric. If you provide the model number I will see what I can do to exactly narrow it down. But you can try turning the pad by hand and should feel some resistance and the motor not turn, if it does I would think the bearing or something rubbing on the housing.
Jan 27, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
Porter Cable 7336 polisher - pad/backer plate will not begin to start without starting it by hand. Will changinging the brushes fix it?
The first thing to do is to make sure the unit is completely clean. Many of the contaminates that get airborne while you are sanding can and will affect the motor's performance with time. Pay particular attention to the brushes/commutator or any kind of centrifugal switch it may have.
Jan 02, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only Logo
89 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
