Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
Oiling system inoperative! No ownwer's manual on hand.
I assume clogged oil feed line.
Where can I buy or download an ownwer's manual or obtain repair procedure? Bert, dbautz@centurytel.net I have the same problem with my 2014, have you been able to find a fix yet? If so, how?
THIS WORKED FOR ME....I've had that problem for quite awhile. I finally decided to try to fix it. I took the chain and blade off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain blade bolt. Once I found the hole, I then drained the chain oil resevoir, and then using the air pump, blew out the hole from the blade area to the resevoir, leaving the oil cap OFF. Upon refilling the resevoir with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the resevoir empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Posted on Apr 02, 2009
    Sergeant:
  • 359 Answers
A fix that sometimes works is to add kerosene to oil tank where the oil would go normally and rev saw several times with out load holding blade in down position over a piece of dry card board so you can see the oil spraying on the piece of cardboard careful of moving chain
Posted on Jan 02, 2009
3 Suggested Answers
SOURCE: Mcculloch chainsaw 2014 Eager ****** Model 00032-14
light on laptop screen comes on but does not stay on
Posted on Oct 18, 2008
plkruger
  • 32 Answers
call 1-800-521-8559 select parts, ask them to email a owners manual to you, it's free, it's EZ
Posted on Feb 19, 2009
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
What is gas/0il mixture for mcculloch 2.1ci eager ****** model 60013203
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Which brand chainsaws have manual oil pump
None use a manual oil pump anymore. Automatic oiling is the way to go.
Dec 26, 2009 | McCulloch Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Eager ****** not so eager when it warms up!
If the chain locks up it may be to tight. Try loosening the chain and see if the same problem happens.
Jun 20, 2009 | Garden
Oct 17, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
1,128 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
