Bluetooth Printer does not work properly
I have an Epson PX700W printer. I have connected it to the laptop using 2 USB dongles. Using the bluetooth software that came with the dongles I have found that the printer is connected and recognised as a printer. I added the printer to the control panel printers section and made it default. I have downloaded and installed the drivers and software that is neccessary for it to work.
However when I press print (test page is the same) the document pops into the printer queue, and the Epson software registers it as printing. Fine you might think, except the printer does absolutely nothing.
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructions.
Hope this helps. Bud
Posted on Jan 28, 2009
I have an Acer 5321-1805 laptop and installed a Medalink version 3.0+ class2 dongle, but I can't print on my hp 6980 deskjet printer which also has a dongle installed. It pairs, but the printer driver...
Welcome to FixYa.
You have to configure the Bluetooth settings of the printer first. I assume that you have the HP bluetooth dongle on your printer.
Configure Bluetooth settings
You will need a USB cable to configure the Bluetooth settings
  • Connect a USB cable from your computer to the rear USB port on the printer.
  • Open the printer Toolbox.
  • Click the Configure Bluetooth Settings tab.
  • Configure the settings you want, and then click Apply
    Keep me posted.
Sep 09, 2011 | Computers & Internet
Tip
How do you solve a Bluetooth Dongle Problems?
<p>Bluetooth wireless technology allows many devices to connect wirelessly to computers, keyboards, mice, speakers and even other computers. Most desktop computers come with Bluetooth pre-installed adapters, allowing many to purchase and install an external Bluetooth dongle adapter. These dongles are usually connected to an available USB port and automatically installs without much fuss, but there is the possibility of going wrong, because usually when people and computers interact. Fortunately, hiccups are usually quite easy to solve. <br /> <p><br /> <p>1. Unplug the dongle on the computer using the "Wizard Safely Remove Hardware". Look for an icon in the Windows taskbar that looks like a USB connector with a green circle and check mark next to it. Wait a few minutes, and then reinsert it. This will cause the drivers are loaded on your computer and your problem. <br /> <p><br /> <p>2. Restart the computer; make sure the dongle is working properly. Some drivers need to restart your computer before working properly. <br /> <p><br /> <p>3. Download and install the latest drivers for your Bluetooth dongle. If you are unsure of where to get it, Windows can do it for you. Open "Control Panel" menu "Start," click "Hardware and Sound" and then "Device Manager". Expand the Bluetooth Radios section "from the list that appears, right click on the Bluetooth adapter, and select" Update Driver ". Select" Search automatically for updated driver software. " <br /> <p><br /> <p> <p>4. Then remove, reinstall the Bluetooth dongle. Right-click on the Bluetooth dongle "Bluetooth Radios" from the "Device Manager" and select "Uninstall." Remove the dongle from your computer, restart the computer. Connect the dongle back and reinstall drivers for Windows.
on Jun 26, 2011 | Televison & Video
Will this adapter work with a All in one 5500 printer?
Hi as long as the printer is bluetooth capable then this dongle will pick up the signal and it will then let you use the printer.
you should have no problems using it as long as you have the printer software installed on your computer and you also need to install the drivers for the usb bluetooth once you have done this you need to make sure the printer is switched on then you need to scan using the bluetooth software then just connect with the printer, this will then pair the devices and will let you use the printer via bluetooth
let me know how you get on or if you need further assistance.
plz can you rate this solution as i have pages on unrated posts filling my page, thanks
Aug 25, 2010 | Kodak (1723949) Bluetooth Wireless Adapter
Using Windows XP have an older class 1 bluetooth dongle and a new 2.1 dongle. 1 on computer and 1 on the printer Canon IP4200. Will not work. Loaded both cds for the bluetooths. Thanks a kolk
activate the bluetooth on the printer ..and try to locate the device using the laptop search for device feature ...if there will be no compatibility ...just get a usb unit for the laptop ...there are cheap ..and it will work ..
Nov 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Use of polaroid PoGo Zink printer with PC
The PoGo can connect to a PC with Bluetooth only. Once you establish a Bluetooth connection with your PC, simply copy any JPEG file to the PoGo using Explorer. No printer driver is needed, just copy the file to the PoGo over the Bluetooth connection.
If your PC doesn't have Bluetooth, you can buy a USB Bluetooth dongle for $5-$20.
May 04, 2009 | Polaroid PoGo Digital Photo Printer
V220 mouse bluetooth connection to laptop with own bluetooth
You can't; the V220 doesn't use bluetooth connectivity. I believe it actually works on a 2.4GHz radio frequency, so you need the included dongle.
Apr 21, 2009 | Logitech V220 Cordless Optical Notebook...
Setting bluetooth on a Epson stylus SX600FW
the bluetooth dongle for your printer is sold separately. call epson store to get one.
Jan 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Connecting to printer via Bluetooth but driver is missing
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
Dec 27, 2008 | Zebra QL 420 Thermal Label Printer
Bluetooth dongle
Not really, what operating system are you using? on the printer itself set it to bluetooth settings and dont put n a code set but set it to discoverable, then when printing dont do a file print, instead right click on the file and then on your send to option if your computer is detecting the dongle one option will say stylus rx585- then it will print it. one thing that you can check is as belkin manufacturer if their bt dongle is compatible with epson, and FYI bluetooth printng is for photo printng only. doesnt look as good if you are going to print a document or text docs..
hope this helps, and if you have inquiries email me back
if it solved your issue pls rate as fixya, thanks!!!
May 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Bluetooth not found by computer
Hi Bryan,
if you installed the printer by USB, the computer will have installed the drivers for that connection. ( Although USB is Plug and Play ) I,d refer to your user manual regarding bluetooth connectivity, also your printer.
The bluetooth device ( printer ) usually has to transmit signals, to be detected by the Computer. You,ll probably find that if you enable bluetooth on the Laptop. And turn the bluetooth on the Printer ( if Applicable ) by turning on/off or other function ( sync et,c ) the laptop will sense the Printers signal.
Once you have a communication between the two your setup.
I,d suggest unplugging the USB, as the laptops software/hardware, will assume that the printer already has an adequate connection, and will look no further.
Hoipe this resolves your questions regarding Bluetooth Connectivity.
Mike @ compurepair.
Mar 07, 2008 | Canon PIXMA iP90 InkJet Printer
364 people viewed this question
jasbo
jasbo
