Question about E-Machines T2642 PC Desktop
Emachine t5026 not power on. replaced psu.
Replaced psu. stndby lght on motherboard blinks with original psu and stays lit with new psu but still no power. the tower shut off in the middle of working one day. i tryed to turn tower back on and the power "E" button would blink as i held it in and the fans would click on. as soon as i releaseed the power"E" button everything stopped. After doing this a few times the tower would not respond at all to me pressing the power button.
  • tkagpainting Jan 02, 2009
    to guru: how would i test the memory or find if something is grounding.
  • sellis30 Feb 04, 2009
    I have the same computer (emachine t5026) and mine did the exact same thing worked fine one minute and cut off the next tried to reboot pushed power button fans were struggling to turn un hooked fans and it booted up but was only on a minute the cut back off hooked fans back up and again struggled to turn unhooked them booted back up then while booted up hooked fans up computer ran 5 minutes cut off and now will not boot up green light on back of tower is on greenlight on mother board is on and it sometimes makes a faint humming noise but it will not cut on. Thought about relpacing fans but am afraid I do that and it still doesn't work then I've wasted money. Any suggestions
    Novelist:
    Champion:
  • 233 Answers
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Posted on Jan 02, 2009
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Nov 06, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It sounds like a car tying to start and the lights on the front flash as does the light on the mouse, but it won't start.
Mar 29, 2010 | E-Machines Emachine T5026 power supply **...
Emachine T5508 desktop will not power on. There
thats not true but the fan skould be running if the power supply is working. take the power supply out and take it to best buy they can check it for you.bobg22
Nov 15, 2009 | E-Machines eMachines Desktop PC
EMachines T3828 won't turn on. Any way to determine whether problem is power supply? thx!
Had the same problem and ended up replacing the PSU. Try re-seating the memory and video card first but if your not getting any power on beep codes then it is likely that the PSU and possibly the motherboard have failed (google emachines power supply failure).
Try a new PSU, it worked for me and was a fairly cheap fix if nothing else works.
Sep 19, 2009 | E-Machines Emachine T5026 power supply **...
Same problem
I would try to replace the PSU and see if that makes your computer boot. Do like a guess and check. If its not the PSU, maybe try a new motherboard. Does the computer not boot, or does it beep when turned on? I hope this helps solve your problem
Jun 22, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
T5026 won't start up
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Jan 03, 2009 | E-Machines Emachine T5026 power supply **...
E-Machines T2642 PC Desktop Logo
201 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
