Question about Kenmore 45081 Front Load Washer / Dryer
Oil Like Stains on Clothes
We are getting spots/stains that look like oil. Any ideas as to why?
  • Anonymous May 05, 2008
    was getting dime size stains on the clothes. after reading the previous problem listed here, I took the cap off the agitator and foung about a cup of softener still in the agitator. also a residual of a waxey material was coating the inside container where the softener is poured. all the drain holes in the agigator for releasing the softener were clogged. I had to get a steel rod (long pin ) to unclog the holes. Put in a bottle of vinegar and ran it through a couple of cycles and it's like new......
    Thanks to this website!!!!
  • 725 Answers
I think you may have a Detergent/fabric softener build up. Run your washer in a normal cycle and see if you have soap suds..if you do you have a build up you have been using to much soap. use a vingar flush to clean out the extra soap/Detergent.. Do you use Fabric softeners liquid can leave greasy spots your garments. The spots can be removed by re-washing and drying without the softener This is actually a wax. let me know if this helps..
Posted on Aug 24, 2007
    President:
  • 1,462 Answers
Possibility is that the bearing seal is breaking down and oil from the bearings reaching the clothes. if so, the bearings will shortly follow. not an easy job and you are faced with a bill if i'm right
Posted on May 12, 2007
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
2nd time I have oil stains on my clothes from Whirlpool LSR9434PQ1 and nothing gets them out. Need to know how to get the stains out and what kind of washing machine is better so that I can replace. Spent...
You can try Lestoil to get the grease out, it has surfactants that will help break up the grease, if they aren't set too deeply. This seems to me to have a leaking transmission if you are constantly getting grease on the clothes. A better machine is anything newer that you can afford, quite honestly, there is only your preference to what you want/need for your usage.
Hope this helps, please rate service and comment, Thank You,
Joe
Sep 01, 2011 | Whirlpool LSR9434PQ Top Load Washer
The machine is spotting the clothes/ It looks like dark fuzz, but its staining the whites. How do you remove the agitator???
Amazing, my washer was doing the same thing, i was getting unremovable stains on my dark clothes. to fix this problem you have to changed out the gearcase...leaking oil....
Sep 13, 2009 | Washing Machines
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator was screeching, now there is grease/oil stains on clothes
Main seal and bearing have gone bad and needs to be replaced
Jun 02, 2009 | Washing Machines
Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
May 13, 2009 | Washing Machines
Oil stains
Hello
Welcome to Fixya
My name is Huum,
You said, you have been getting oil stains on some of my clothes.
this means your washer has a leaking seal and oils is coming out onto your clothe.
Water is getting into the seal and bearings.
Do not waste any time. Get service out there right away.
If this is caught early you may have a chance to save a lot of money!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
Steam cleaning an oil spot on driveway
Hello gktweets,
Cleaning oil stains off of your driveway will require the right "products". However, if the oil stains are a heavy buildup then you will definately need to steamclean them off first.
What you will need to do is apply a sodium hydroxide based degreasing product (basically most types of degreasers) to the oil stains and let the product sit on the stains for a few days allowing for the degreaser to completely dry.
Then you will want to use a "hot" water pressure washer to steamclean the oil stains off. If you do not have a "hot" pressure washer then a cold water unit will work too just not as effectively.
If you do not have access to a pressure washer at all you should re-coat the oil stains with your degreasing product then scrub with a broom and rinse with a garden hose simultaneously.
After your driveway is completey dry and the oil stains are still minimally present you can apply a dry product known as Bio-Dry. They have videos posted up on you tube as how to purchase and apply the product.
This product will go to work on the leftover stain and will work "over-time" as far as lifting the stain out of your driveway.
You can see before and after pictures here at this site: http://www.DrivewaySteamCleaning.com
Feel free to leave any comments on the site as well, they are much appreciated.
Hope this information helps you.
Jul 26, 2008 | McCulloch MC1275 Steam Vacuum
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
417 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
