Question about Eclipse Metrologic MS5145 Barcode Scanner
Scanner won't scan red ribbon - Eclipse Metrologic MS5145 Barcode Scanner
Metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
Posted on Jun 04, 2009
Lost color when scanning slides
Hi Silva,
i think the scanner,s ribbon cable is faulty.
regards,
nuwan
Jan 10, 2014 | Epson Perfection V500 Flatbed Scanner
How to solve the hp laser jet 52 scanner error
there are three usual faults that cause this
1. the scanner is unable to locate home position- remove the scan glass/ clean and lubricate all rails
2. the ribbon cable has open circuit on tracks- replace the ribbon cable connecting the scanner to printer
3. the printer main PCA has failed and cannot control the scanner- replace main PCA
Dec 17, 2013 | HP LaserJet 3055 All-In-One Printer
Won't scan
Hi Betty,
Try this utility and it should give you detailed information about whats missing when you try using scan option from HP Solution Center.
Click here >> HP Print and Scan Doctor
Download this utility and run the program.
If it gives any Red X on Drivers, you might have to uninstall the software and reinstall.
Click here to Download Drivers >> HP Driver Download
Regards,
Sean
Apr 21, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
It won't scan and the scan button just keeps blinking.
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps you
Aug 18, 2011 | Fujitsu Computers & Internet
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
I am getting error code 843.01, what is the solution?
Found this information on the web. Hope it helps, because, Printer has been discontinued.
Problem
843 error; 843.01; 843.01 error; Scanner error; Scan error; Cannot scan; Will not scan Solution--Overview
An 843.01 error is generally caused by the Bottom ADF Cable on the scanner being loose or unplugged. Did the error return?
Yes: Continue to Contacting Lexmark
Items is Discontinue
Nov 16, 2009 | Lexmark C772dn Laser Printer
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
Scanner locked.
Normally that is an issue with the ribbon cable from the scanner to the main board if the latch is in the correct position.
I would securely reseat that cable, bias it somewhat upward.
Check the ends of that ribbon cable to be sure a portion of the silver print isnt pealed back.
No reset code for that. The scanner may have failed also. The sensor inside the scanner may be bad.
You can try going to the Xerox.com site under drivers and downloads and load the newest firmware. But I doubt that is an issue.
Only other thing i could think of would be the scanner not returning to the full home position due to an obstruction.
Or the scan head itself being out of the rail latch, or even the end of the scan head could be broken, not scanning straight.
Mar 31, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Eclipse Metrologic MS5145 Barcode Scanner Logo
316 people viewed this question
Top Eclipse Computers & Internet Experts
yuda kaufman
Level 1 Expert
 Russ Hill
Russ Hill
David Fischer
Are you an Eclipse Computer and Internet Expert? Answer questions, earn points and help others
