Question about HP PSC 1315 All-In-One InkJet Printer
Colour is printing but not the black
When asked to print a word document the printer simulates the job but when the paper comes out nothing is printed. the printer does print coulour pictures. cartridges were replaced +- 2 months ago.
  • 1 more comment
  • Anonymous Jan 03, 2009
    same problem, same product.
    in my case, I just replaced the black cartridge and the SW recognizes it as full of ink. I already used the SW to clean the cartridge with no success.
  • mfg345 Jan 17, 2009
    Anybody know more about this issue, since I'm seeing the same thing. Replaced all print cartridges and still no black, even though other colors are fine. Tried realigning and cleaning with no luck. Prints the test page (butterfly) perfectly, but all other pages either come out blank or with just cmy.
  • shotzeemarie Jan 22, 2009
    I don't have a solution either. I am getting time out errors when I try to print black.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Colour printing not working
Hi ,
While printing go to the printer settings nad check if any Black print option is clicked. Also check the color cartridge status.
Jan 26, 2010 | Samsung CLX-3170FN All-In-One Laser...
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Feb 19, 2009 | Sharp MX-2700N Color Copier
Black colour prints faded
Have you adjusted the settings on the machine and in the driver to heavy stock? That will make a difference in the transfer of the image adn the fusing.
Telling the machine you are printing onto heavier stock makes a differenec. if this is a print job, it will have to be changed on the machine and in the print driver. The machine will ask you to confirm the paper settings when you add paper.
You have to select the paper type in the driver.
Mar 17, 2008 | Xerox DocuColor 12 Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
