Question about Microwave Ovens
Microwave shuts off after 2 seconds
I have a Panasonic Microwave (NN-S615WFX); mfg. date 2007- 08. It won't finish the job. I can enter a cooking program, press start and it will go for approx. 2 sec. and shut it self off ?
  • Microwave Ovens Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer (above) to get it fixed free.
Posted on Jan 03, 2009
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
You can find an authorized Panasonic servicer here.
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
The microwave shuts itself off after 3-5 seconds on all cook settings
i have model # nns 977s it shut of and show H98 what is wrong?
Dec 26, 2009 | Panasonic NN-T964SF Microwave Oven
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Oven shuts off on cook after about 2 seconds
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Microwave shuts down after 5 seconds
chech the control panel and wiring and thermal sensors..
Sep 23, 2007 | Panasonic NN-H965 Microwave Oven
Microwave Ovens Logo
341 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
