Server Keeps on initializing at startup " Slot 0 Smart Array E200i Controller Initializing..." What shall i do to bring it up
SOURCE: Smart start utility doesn't detect controller disk
Lets have a few more details and see if we can get it solved. Is this a new server that has never been used? If used, was it used before by you successfully and you are just now having the problem on reloading? What version of SmartStart are you running? What type of drive controller is in the server? How are the drives connected to the system? By the on board controller or via controller card? Also, check the BIOS settings to see if the system is setup to boot from the controller you have in the system and there are no interupt conflicts. Kenneth
SOURCE: Trying to install Windows 2003 on to ML350 G3 server
http://www.downloadatoz.com/driver/item_199703.html
try this
Have a nice day!
tc
SOURCE: getting drive array problem
Even the 1st generation will have a ROM based Hard Drive Array utility which you will need to make yourself familiar with. Find out the hard ware you are dealing with, make sure it is functioning properly, and work your way to the software configuration.
SOURCE: SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
SOURCE: server starts but no display in the monitor
how i get the server end rank for him the game is cunter strke 1.6
