Question about Cobra 29 LTD CB Radio
Outputt vs 4 watt
I know I can get more power out of it. I need some technical shema and how to doo it.
Take a look out on The Quack Shack
http://www.thequackshack.com/
Posted on Jan 09, 2009
What is the speaker output per channel for technic se-350?
seems to be 22 watts rms, 35 watts peak at a 4 ohm load. with 8 ohm speakers, the power would be reduced 50%, but the distortion levels would also be drastically reduces
Jan 02, 2015 | Audio Players & Recorders
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
I have two 12" kenwood KFC-W3003 (svc) 4 ohm 600 watts max 160 watts RMS subwoofers and two 12" Rockford Fosgate Punch RFP-4812 (svc) 8 ohm 400 watts max 200 watts RMS. I was wanting to know how i...
It can't be done unless you choose to include some power resistors in your circuit for impedance matching. The problem with that would be some of your power will be lost in the form of heat across the resistors without the benefit of contributing any sound.
Also, the amplifier's damping factor will be compromised, so you may notice a loss in sound clarity. It's possible that you might not easily tell with subwoofers, depending on the enclosures they're mounted in, and whether they're isolated in a trunk vs being in the same airspace with you (hatchback, SUV, or pickup truck).
Nov 13, 2017 | Rockford Fosgate Car Audio & Video
I HAVE A HP PAVILION SLIMLINE (S5310F) AND WANT TO PUT IN A VIDRO CARD, SO I NEED A LARGER POWER SUPPLY. HOW DOO I DO THAT?
Replacing the Power Supply DEPENDING on the power needed? you might have to settle for a slower, weaker performing video card. Make sure you check the video card power supply specs needed.
Chances are you will max WATT at about 300WATTs less then what you'd need to power a gaming video card. OR you could do as I'd do.
Remove everything and place it all in a standard tower case - install a 650WATT power supply in to the new mid/full size case and BAM solution found.. Have fun and a great day to ya.
Oct 10, 2010 | HP (0950-3952) (09503952) 425-Watt Power...
Hi, I have a hyundai grandure 2000, i need the electric mirror wiring diagram. just couldnt find it anywhere. can you help please. All the mirror just wont move at all. the rest of the buttons on the door...
just go on ( hmaservice.com) registred your self you will find your électrical shema your looking for.but you must click for a XG série it's the same car and go for a 2001... click on SHOP,than click on body électrical system after on power mirrors (this is to check the actuator) and for the shema click on ETM than go on( power outside mirror) and there you go you have your shema please reply thanks!...lipak!!...
Apr 26, 2010 | 2001 Hyundai XG300
Wat power does this radio push
Generally All CB Radios will only push 4 watts. This is only if you have a SWR of 1:1
Jul 11, 2009 | Magnum S9 Base CB Radio
Power button flashing but tv won't turn on
If the power light is constantly flashing even after you have unplugged the set for a min or two and the plugged it back in, the you will need to replace 4 capacitors on the "DM" board. The "DM" board is located under a metal shield on the left side looking from the back of the TV with the back cover removed. They are 1000 microfarrad and rated at 16 volts DC. Available from radio shack or just about any electronics part supplier. Once you look at the circuit board, you will see the defective ones, they will have the tops swelled up. You will need at least a 40 watt soldering iron, .032 solder, and "solder wick" to do the job. Make sure you get the polarity straight when instaling them. If this explanation is too technical, then call a repair shop and ask then how much to replace the 4 capacitors on the "DM" board.
May 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Cobra 29 LTD CB Radio Logo
52 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
