Screen not working
It's an Inspiron 1525 laptop and though it says resuming windows, and goes through normal routine, the screen remains blank.
  • ahmedsh241 Feb 14, 2009
    My dell Inspiron 1525 laptop do that but i make restart or trun it off and trun it on again or plug& unplug charager ... the lcd work normally .... I whant to know is the (inverter is damage) or not.
    Problem Solver:
  • 5 Answers
Hi, I'm a laptop technician and if the screen is blank as in there is nothing showing on the screen at all (even when the laptop first starts up), but the laptop sounds like it is starting normally then the backlight or invertor for the laptop screen has probably failed. This is very common.
The easy way to check this is to plug the laptop into a normal PC monitor (if you can) via the monitor out port on the laptop - you may have to press Ctrl + F5 to get a display on the PC screen. If you can get the laptop to show an image on the PC screen then the main laptop itself is fine, and the problem is almost certainly a failed invertor or backlight.
Assuming you *could* see an image on the PC screen, you should then press Ctrl + F5 so that you *can't* see an image on the PC screen any more (this is very important). Next unplug the laptop from the PC monitor (if you did the above) and look VERY closely at the laptop screen. You will hopefully *just* make out a very, very feint and very dark image on the laptop screen. Bear in mind that you may need to re-boot the laptop to get a moving image that you can detect (like the Windows boot up screen for example). If you *can* see a very, very dark and feint image on the screen then the backlight has failed. If the screen is plain bright white or there is no image then the invertor has gone.
The invertor (or inverter as it is sometimes spelt) is a smaller circuit board that sits in the screen housing, the backlight is a very thin "flourescent" kind of tube light that is built into the screen itself. The invertor can be removed and replaced pretty easily by most competent people without much trouble (takes maybe 30-45 minutes to do). The backlight on the other hand is very hard to remove without damaging the screen itself and should only be attempted by a specialist laptop repair company.
Both the invertor and backlight parts are specific to the screen so you must get exactly the same to replace the faulty one with. Online auctions are a good place to get s/hand or new spares, just tap in the *exact* part number or laptop model number and you will usually find someone who has the bit you need.
I hope this helps.
Posted on Jan 04, 2009
Resumes windows from hibenate but the screen is blank
Try this: ( windows 7)
Usning an EXTERNAL USB keyboard, reboot the laptop and enter the
"Restart with low resolution display"
Login as normal
Go to Control panel and change resolution to normal settings
Visit the Dell site and download the latest drivers for the graphics card.
If this does not help, try changing the hibernation settings:
Start / Control panel / Power options/ Hibernation tab/ click to clear the "enable hibernation" box
This wont cure the problem, but it will give you a workaround
Dec 31, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1525 screen goes black, image is very faint on the screen. computer remains on. What is the problem
Sounds like the backlight for the screen has died the part isn't that pricey but having it put in will probably cost almost as much as replacing the laptop. You can always plug into an external monitor, however that is not very portable
Oct 11, 2010 | Dell Inspiron 1525 Laptop
When I close my laptop during normal use, Instead of going into hibernation as normal, the screen just goes blank (with the laptop still running). However I cannot resume the computer and have to just turn...
hi when you close your laptop it goinng to stand by mode if you press any key it should resume. you can change this options in control panel, power option then go to advanced tab. By the way hibernation need to be enable and is different than normal shout down. if you need more help let me know.
is it help please rate it
Sep 06, 2010 | Computers & Internet
Blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Apr 25, 2010 | Dell Inspiron 1545 Notebook
When i start up my laptop it ses "lauch start up repair" or "start windows normally" which ever 1 i choose the laptops screen goes blank andd nothing happens!! what shall i do??
if you are using windows xp....
insert the windows xp cd.....
and wait until it r to enter recovery console...
press r ....
select the partition "usually c:"
and follow the instructions ...that will solve your problem
Dec 30, 2009 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
660 people viewed this question
David Payne
David Payne
