Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quite partener 1
My dishwasher is just not cleaning anything. the top rack is not cleaning anything at all. the bottom rack is not cleaning that great. occasionally the dam thing will not even fire up at all and i'll get blinking lights. i then clear it out by runing the auto-troubleshooting program... but it dosn't fix the top rack.
  • Whirlpool Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Sep 29, 2010
Quite Partner 2 no top rack wash cycle
The top rack in your dishwasher not working, the recirculate pump may be clog or Gump up with food broken glass and plastic check sump,
Apr 20, 2014 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The dishes wont come clean on top rack? the bottom rack is clean..we tried cleaning filter and making sure the wash arm wasnt hitting anything..we tried different wash settings..please help ...
Check that the top rotating arm jets are not block. These often get blocked by pieces of food or other solid particles, this is the normal problem.
Feb 02, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Our Whirlpool dishwasher, DU1145XTPBA, has almost quit cleaning the dishes. It started with dishes on the top rack. My husband was told by rep to replace the top unit. That did not help at all. Now the...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Not enough pressure to top rack
PULL WASH ARM OFF OF THE TOP RACK AND SLAP AGAINST YOUR HAND AND SEE IF FOREIGN MATTER IS LODGED IN ANY OF THE SPRAY JETS. CLEAN AND REATTACH
Jul 22, 2009 | Whirlpool GU1200XTLS Stainless Steel...
My dishwasher cleans the bottom rack but doesn't get the top rack clean, and I'm not blocking anything or over loading. Any ideas?
there is a trap in the bottom of the dishwasher. Have you made sue that there is nothing stuck in there or anything blocking from the bottom?
Apr 16, 2009 | Dishwashers
Top rack not getting clean
you may have a bad chopper. put a couple of coffee mugs upright on the top rack turn the dishwasher on and see if the mugs are filling with water give it about 1 minute. if they are mot filling up you have a problem with either the recurculation pump or the chopper. it's usually the chopper
Mar 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
209 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
