Question about Philips 27PT8420 27" TV
My philips 30pw633f/35a tv won't play my ps3
I have had my PS3 hooked up to my HD tv and now want to play on my philips TV and it won't except my PS3, my screen goes black and white with a wavy screen!
5 Suggested Answers
lordrussell
  • 47 Answers
SOURCE: I hooked the ps3 to the philips tv. turned on the
give this a try...
Leave the TV running, go over to your PS3 and turn it off.
Once its off, hold the power button down till you hear a beep, KEEP HOLDING THE POWER BUTTON till you hear a double beep. The PS3 will shut itself off.
Give the device a couple of seconds, then hit the power button one last time (just turn it on, you don't have to hold it).
If all went right, your baby is back up and running...
Posted on Oct 11, 2010
SOURCE: HD WONT WORK ON MY PS3!!!
finally found the answer via a nice write up here:
http://www.notcolor.com/2009/01/24/playstation-3-ps3-stuck-in-480i-can-not-change-to-hdmi-or-component/
Posted on Jan 25, 2009
bernardlunda
  • 318 Answers
SOURCE: #27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Posted on Apr 30, 2009
SOURCE: I bought a used Philips tv, model # ocv625c123 ,
I found the switch on my SAT box to switch it fro m ch 3-4. I still don't know why the tv won't go to ch 3. But it doesn't matter now.
Posted on May 18, 2009
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
I had my ps3 hooked up through hd and it played fine. when i tried to hook up my ps3 to another tv through audio video connect, it wont show on the tv.
You'll have to do the Video Reset:
Set up your console the way you would like to play
Make sure your TV is on the right channel
Make sure your system is in Standby mode
Hold down the power button for 2 beeps (it will turn on and then off)
Turn on your console and everything should work normally
Feb 17, 2011 | Sony Playstation 3 (PS3) Console
Doesn't recognize non HD TV
hook your PS3 to the tv with the regular cord, put the tv on the channel you want. with the PS3 off but switch in on press and hold the power button until it beeps twice then release. you can also do this the other way round (SD to HD).
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Green screen
I am a TV repair technician and what you are experiencing with your plasma and PS3 is a HDMI compatibility problem. The Philips plasma and the PS3 electronic handshaking (EDID) are not right. This happens alot with an older version of HDMI like 1.1(Philips Plasma) and a newer version of HDMI 1.3 (PS3). A tv firmware or PS3 firmware update will not resolve the problem. I would recommend using the HD component video cables and that should work just fine for playing High Definition BluRay movies.
Oct 05, 2008 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips 27PT8420 27" TV Logo
946 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
