Question about New Home HF-2022
My feeders are not up. My fabric will not travel and pass under my pressure feet. I don't have a instruction book. Please help. Thanks Model: New Home HF2022
  • 202 Answers
I'm not sure about this model but if you look inside the door that covers the bobbin case you may see a lever that raises and lowers the feeddogs. It might also be on the back bottom or on the right below the handwheel. If you find it and it doesn't help, most likely the bottom cover will have to be removed and you will have to oil a bullet shaped object that is stuck and work it until it frees up..
Good luck
Posted on Jan 03, 2009
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
What is wrong with machine I have tried all the instructions and it makes a horible button hole
most sewing shops/fabric shops that sell or service machines have people who are willing to show you how to do it regardless of the make of your machine
there is a knack to the job that is difficult to print in instructions
Sep 02, 2015 | Sewing Machines
Fabric not advancing
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Nov 23, 2013 | Janome Sewing Machines
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
What is a walkimg foot machine
A walking foot is a foot with feed dogs, or a similar fabric moving mechanism. This is useful when there are many layers of fabric or slick fabric. Then the top layer of fabric can be made to travel at the same rate as the lowest layer (the feed dogs) or an slightly different rate. Then the fabric layers will stay even for the entire length of the seam.
A walking foot sewing machine has this feature built in. Thus you don't need to adjust extra hardware to keep your fabric aligned. (On some, specific feet are needed to use the feature. However, it is easier to adjust than the separate walking foot that I have for my older Singer sewing machine.)
I hope this helps.
Feb 21, 2012 | Juki MO-644D Mechanical Sewing Machine
No longer have my manual for my euro-pro model 6131 need to see how to use different feet
You don't need the manual for that, although its always very helpful. www.Sewusa.com have a manual for the 6130 but I dont know how close that is to your machine, but you could certainly email them and ask. Or contact the local Euro-Pro dealership may well be the easiest solution.
Different feet are for different techniques and any good sewing techniques guide book should help you through.
Here is a good website on sewing feet.
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/
If you are assembling garments then you will still use the standard pressure foot for 90% of the work. You would change to use the zipper foot to put in zips, maybe the blind hemming foot to turn up straight edge fabric (can't use on curved hems very well unless its a knit) or a rolled hem foot for turning in a small edge and stitching it. And of course the buttonhole foot, for getting nice neat buttonholes.
Your machine's accessories case may have these feet and a few others.
You may find sufficient info at www.sewing.about.com on where and how to use these feet.
Jun 16, 2011 | Euro-Pro 6131 Mechanical Sewing Machine
Needle stays in one place. Fabric does not feed
There is a latch under the the feeder lpate next to the bobbin lift it up to lift the feeder feet. wcbotha@yahoo.com
May 10, 2010 | Singer 7426 Mechanical Sewing Machine
Feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Mar 19, 2009 | Kenmore 15343
FEEDER FEET WILL NOT PULL FABRIC,REVERSE WORKSB
I'm sorry to say that it sounds like you have a broken gear that is preventing the feed dogs from moving properly. Depending on the machine, this could be a very expensive repair.
Feb 01, 2009 | Kenmore Sewing Machines
New Home HF-2022 Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
