Question about GE JRS04 Electric Single Oven
GE TrueTemp Oven - F8 Code, Locked Door
How can I unlock the oven door? I have a GE TrueTemp Double oven.
  • christine078 May 03, 2009
    I have the same oven and after I used the self-cleaning option, the door would not unlock. Can anyone help?
  • Laura Hernandez Nov 12, 2011
    jkp15 Code F8 how do I fix it?
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
Posted on Oct 28, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
shyamo108
  • 106 Answers
SOURCE: GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Posted on Mar 24, 2009
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
My GE JTP45WOV2WW Double Oven is beeping with an F2 code and I don't know how to stop it
F2 means the controller thinks the oven is over temperature. (590degrees if door is unlocked, 990degrees if door is locked). This is a problem with either your temperature sensor or the control board.
If the temperature sensor is about 1080 ohms at room temperature, it is very likely the control board.
These can be rebuilt: www.fixyourboard.com
Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
GE Electric Double Oven Door Will Not Unlock
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Dec 24, 2007 | GE Profile JKP56 Electric Double Oven
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
GE JRS04 Electric Single Oven Logo
1,004 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
