Question about Sony VAIO PCG-V505CP Notebook
In battery is dead
Whenever i turn on my sony laptop I have to set time and date .
its 2years old this problem started recently
  • 2 more comments
  • william_lwan Jan 02, 2009
    its model > FS315E
    ITS MODEL FS315E
  • Jason Edinger May 11, 2010
    Still looking for a manual of sorts.
    That is the cmos battery that is dead. It's generally a cr2032 button cell. What kind of laptop do you have so I can get you instructions how to replace it?
  • 124 Answers
Http://www.fixya.com/support/t231868-sony_vaio_cmos_battery_location
Basically, unscrew the keybaord screws, lift up keyboard, and you should see it.
To unscrew the keyboard, turn the laptop over and any scrwe hole that has a little keyboard symbol next to it, unscrew.
Posted on Jan 02, 2009
  • 4 Answers
Mostly this problem comes up if you dont shutdown your computer properly as in by offing it by holding the power button and stuff like that. What you can try doing is when you on the computer it should let you choose if you want to go to the BIOS menu or System Recovery and you go to System Recovery and if you would like reboot the whole computer or just choose to repair the windows and it will reinstall the windows files only which should take care of the problem.
Having to set the date and time every time I change the battery.
Your clock battery is dead. Simple to replace. Any place that has batteries should have what you need. Just find the number on the old battery. Good Luck
Mar 01, 2016 | Sony A55 Digital Camera
The date and time is asked whenever the camera is switched on
Have you set the date and time? If so then your camera's date battery is probably dead and needs to be replaced. First get yourself a CR1220 battery, most often found at your local Radio Shack or online at amazon. Then open the camera's terminal cover (where your USB is) and using your fingernail. Open the battery holder, remove the old battery, and replace with the new one. Reinsert the holder with new battery in your camera and turn on your unit. set the date and time and you should be all set. For further information see your instruction manual or download from Canon at:
http://gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf'
The instructions for changing the date battery start on page 137.
Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A510 Digital Camera
I have got two T21, both of them have the same syptoms. The batteries are dead, need to input date and time each time when they start up. Recently, the power of the laptops disconnected suddenly when...
The BIOS battery in both laptops are flat and needs to be replaced.
This is why the Date and Time needs to be entered each time you power up because it cannot retain the BIOS settings.
Jul 08, 2009 | IBM Computers & Internet
162-System Options Not Set; 163-Time & Date Not Set
The bios settings are being lost during offtime. This is due to the cmos battery being dead. Most units have a round 3-volt lithium battery in a clip/holder. A few use a rechargeable battery that recovers if the unit sees frequent use. Can you verify the model number of this unit?
Jun 02, 2009 | Compaq Armada 1500C Notebook
Laptop will not keep current date/time
The BIOS battery is nearly flat and this is causing the time to drift.
Replace the BIOS battery with a new one, then you will need go into the BIOS configuration to set the date and time.
Apr 30, 2009 | Sony VAIO Notebook
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
My cam(sony dsc h7) ask for time whenever battery is inserted
Inside the camera is a button battery used for storing settings. It most likely is dead. It takes soldering to remove it.
Nov 13, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Error
I do not think you fixed the CMOS battery - (backup battery = CMOS battery) According to the error codes, you have a dead backup battery and the time is not set. Makes sense? 161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
hope this will help.
Jun 06, 2008 | IBM ThinkPad 380ED
Ibm screen error
161 - Dead CMOS battery.
163 - Date and time are not set clock not updated.
Replace CMOS Batt: On the bottom of the laptop you will see a screw that holds the memory cover on. (Next to the main Batt) Remove the screw and cover. The CMOS is plugged into the motherboard it is yellow and round tucked in the side of the case. (note how the black cable is towards the center of the laptop and the positive red cable is towards the side of the laptop). Remove the cable connector from the motherboard and pull out the old battery. This can be done by either gently pulling on the cables or using an object like a toothpick and gently tugging at the old battery to free it. With the old battery removed plug in the new battery with the black ground cable towards the center of the laptop and the red towards the side of the laptop. Insert the new battery into the space the previous one set at. Reconnect the memory cover and turn on your laptop. You will have to set the time and date and may have to cycle the computer (reboot) a few times. You can get this battery (CMOS) on eBay or at a computer store they are only a few dollars. (5-8) Good luck in your repair!
you need a cr2025 to replace it you have to pull the tabs of the old one off and tape them to a new cr2025 battery.
then
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
Jan 24, 2008 | IBM ThinkPad 600X Notebook
Whenever i turn on my camera i have to enter the date and time again. This sucks. Help Me! I think that covers it.........
Most (all?) digital cameras have an internal battery that resembles a watch battery. This battery is responsible for maintaining the system settings i.e. date and time. Your's is likely dead. Some of these batteries can be accessed without cracking open the body others can't. Check out your manual to see if you can get to it and replace it - that should fix your problem.
Sep 18, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Sony VAIO PCG-V505CP Notebook Logo
51 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
