Question about JVC RX-552V Receiver
Sub woofer speaker wire
Connection is different than other speaker connections what connector do i need for my sub woofer
    Problem Solver:
  • 13 Answers
Probably an RCA Pin plug
Posted on Jul 21, 2010
I want to connect kenwood woofer sw-07 to pioneer amplifier vsx-d859tx. i am unable to connect please guide me.
I don't recall correctly if your Pioneer has a sub out RCA connector, and if the Kenwood SW-07 has a low level input. So the usual way is to connect it using the speaker wires.
You connect either the FL or the FR to the sub and it should work.
Good luck
Jan 11, 2015 | Pioneer Audio Players & Recorders
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Old receiver, new subwoofer- how to connect?
NOOOOOOOOOOOOOOOOOOOOOOO! Never connect speaker outputs to anything that looks different, like RCA connections. Can you say crispy critter?
Your receiver sounds like it won't send specific Subwoofer of Low Frequency Effects information to the Sub so we're cheating by adding a sub. If you named the model of each we may have a better shot at naming the output you need to use.
I'm curious. How did you have the old passive sub working?
Basically what you may have to do is feed (probable) full range audio to the Sub using an RCA splitter to combine the L and R outputs found, oh, at any Tape Output that you're not using. The Sub will only reproduce what it can. The presence of higher frequencies won't bother it. If it has its own volume control you'll be able to balance its volume with the rest of your speakers.
Mar 18, 2010 | Audio Players & Recorders
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
151 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
