Question about Emerson EWF2704 TV
No sound No picture slight but audible buzzing in flyback. That says it all. Fuse is OK Brown on circuit board around Large heat sinked transisters. "assumption these may be regulators" Can not read part numbers. Had slight smell before it died. Suggesting overheating. No blackened components. Solder is not bright in these areas, but not exactly frosted either. This may be designed to run hot. Very near specification limits of PCB material it looks like. Died suddenly after very slight smell for a few days.
Some small electrolytics died. That was the problem.
Thanks for trying.=
Posted on Dec 08, 2007
Take it apart and check the low ohm resistors around the flyback
and see if your horizonal Transistor is short,Do a diode test on the juntion of the Horiz-transistor does it read low ohms from collector to ground,with set unplug.Let us know
Tv stop working, no picture, no sound. Is there a bulb or what?
Check for blown fuse, if so then check for a shorted horitzontal trainsistor located on a metal heat sink near the flyback transformer on the high voltage module. If those are ok, then you have a bad convergence board.
Sep 04, 2011 | Philips Magnavox 51MP392H Rear Projection...
Rca bday61w66 convergence board removal
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
I believe the solution is: number 2.
I have had a few of these with burned up convergence boards, but it is rare. If you replace one, you must replace both if it has 2.
Check for rings around the flyback solder joints and the little brown fuse next to the flyback (3 are in a line).
Good Luck!
Apr 28, 2011 | RCA HD61W66 61" Projection HDTV
A red blue and green line jus appeared across the screen of my 55 inch rca floor model big screen. instantly my picture and color become distorted
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
May 19, 2010 | RCA R52WH73 Projection Television
Red lines around images--Sony Kp-51ws510
There are two chips behind the large heat sink that need to be replaced. Also, depending on how the chip(s) failed, the fuses should be checked as well. They are very small, wired in, and right below the heat sink on the side nearest the back of the tv. There are 4 and they are brown in color. Can you unsolder and solder in the new chips? The cost for parts would be around $40.00.
Apr 12, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a mitsubishi 1080 series 72" If the power blinks at any time with the set on or off the little green light by the power button will blink and it takes days before the set will turn back on. the...
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Mar 05, 2008 | Televison & Video
Sylvania LC420SS8 HDTV. After 3 months, set won't turn on now. I did a 30 minute reset per manual instructions,still nothing.HELP. Tom.
60" 60P8341A TV NO SOUND NO PICTURE-CAN IT BE FIXED? (INEXPENSIVE)
Should be able ti fix it if you can solder and do basic troubleshooting. If you would like to get the service manual let me know and i will post a link.
Mar 05, 2008 | Philips 60P8341 60" Rear Projection...
My Mitsubishi WS 55511 died.
Mar 03, 2008 | Mitsubishi WS-55807 TV
Power went out, tv won't come on
If you are lucky, it's only a blown fuse, but with a blinking light on the front, this is doubtful. I would pull the back cover anyway and check the fuse. If fuse is ok, then normally if you have no sound and no picture, you have a blown "horizontal output transistor". Look for the big wire (usually red) coming from the picture tube to the circuit board. The red wire goes to a large object on the circuit board called the "flyback" transformer". Usually very near this transformer you will find the h.o.t. (horizontal output transistor). It will normally be mounted on a silver piece of metal (a heat sink), about 2 or 3 inches square or possibly rectangular. The transistor has three pins coming out of it and is probably the largest transistor you will see that has only 3 pins. The upper portion of the transistor will be clamped (or screwed) into the metal heat sink. You have to desolder the h.o.t. and replace it with a new one. The h.o.t. usually costs only about $10.00. If the fuse and h.o.t. are good, then the "flyback" is probably bad and they run from $25 to $100. If the TV is worth only about $200, then replacing the flyback is not recommended, because there is no guarantee that this will solve the problem. Keever.
Mar 02, 2008 | Mitsubishi WS-65908 TV
TV Shuts off by itself
Dec 30, 2007 | Philips 60P8341 60" Rear Projection...
Emerson EWF2704 TV Logo
81 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
