Question about Hotpoint Aquarius WMA42 Front Load Washer
Not draining or spining
Water sitting,and it will not spin
  • Hotpoint Master
  • 3,463 Answers
First thing to do is to check and clean pump filter.U will find this at the rear of the m/c after removing the lower rear cover.On the right u will see a large black hose, remove clip and hose. Be careful as their will be some water run out Inside is the filter, remove and clean.
Refit hose and clip, making sure the hose is on properly..
While u have got the back off ,I wud check the motor carbons for wear. remove belt and 2 screws holding motor, lever motor back and remove motor plug, noting which way it is fitted.
If there is less than 2 or 3 mm of carbon left, then replace the brushes ,as worn brushes can also stop it spinning. Refit belt and test.
Plz rate my solution.
Thanks.
It is much easier to work on m/c if u can tilt it it forwards.
Posted on Jan 02, 2009
    Sergeant:
  • 311 Answers
Hi pete.these washers wont spin if they cant drain.so because of your standing water your pump is blocked or not working .most off the time its blocked.remove frount pannel and get to pump.see if blocked.if not wound have to do voltage check when in spin.please help me with my ratings if ive been helpful.God bless tom
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Not spining and water not draining
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
Jun 27, 2010 | LG WM2277H Front Load Washer
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Water leaking from top
That's an easy one... There is something caught in your diverter valve, keeping it partly open in spin, so that when the water is supposed to be draining out the drain hose, some of it is gettng back up to the recirculator hose, spilling onto the spining tub and then out onto the floor...
Nov 17, 2008 | Fisher Paykel EcoSmart GWL15
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
Kenmore 22422 not draining or spining
Misti, usually no spin, no drain is a broken lid switch. part #3949238. See if the switch is busted off from the screws. Catriver
Dec 26, 2007 | Kenmore 22422 Top Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
