Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
Sony vaio vgn fw21l,loose hinge
The right hand hinge,on the power point side of my sony vaio vgn fw21l has become loose and wobbly,i have contacted sony about this,only 2 b told that its going to cost me the earth just to get it looked at ,and that i shouldnt be too worried anyway,as the laptop will work just fine even with this problem,can anyone give me advice,or experience of this fault,should i be concerned?,or will it really be ok to just leave it as it is?,many thanks
  • 3 more comments
  • Bethmaria Feb 18, 2009
    I have the same problem with my vaio, I am taking it back to the shop I bought it at tomorrow as it was only bought 3 weeks ago. I have a feeling this is one of those annoying design faults. Will let you know what they say
  • siobhan29 Feb 25, 2009
    I have just discovered the same problem! Any ideas?
  • Anonymous Mar 07, 2009
    I have the same problem with my left hinge where i plug in the charger!
  • tjharrop Mar 30, 2009
    Same again - after only a couple of months. I look right silly in meeting with my laptop's gammy hinge
  • Valden May 13, 2009
    i did have a loose hinge on the left now i have it on both, wot do i have to do do get a free repair?
    cheers
  • 3 Answers
My hinge broke on my Sony VAIO and the solution I found was to purchase the Service Manual for the laptop then take the laptop apart and find out which part number the hinge was. Then purchase the hinge directly from USA, which took 1 week to come through and mended the laptop myself.
Sony are doing this to everyone who has problems with the hinges of the laptops as they state the guarantee covers everything EXCEPT the hinges. If you can get proof from a pc repair shop that the hinges are a design flaw then Sony will repair it free of charge, but they will still request a Diagnostic fee which will be refunded if the problem you described turns out to be true.
Posted on Mar 31, 2009
Frak sony my hinges broken
Posted on Aug 23, 2012
HI
I returned mines a few weeks ago to the Sony store and stood my ground while they insisted that I had broken it. I told them about this website and that others had this problem and therefore it was a design problem that was covered by the Manufacturer's warranty. It was taken back and returned a week later, fixed with a letter of appology from Sony Services.
Good Luck!
Posted on Apr 01, 2009
HINGES PRBLM
Yes. Strip down the laptop and screen. The hinges will be exposed and they can be tightened up. Use care because if too tight, they will break the plastic case.
Dec 26, 2013 | Sony VAIO VGN-UX280P Notebook
Sony vaio z2 loose hinges
Laptop hinges cannot be tighten, they have to be replaced.
Check out this WEB site.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Aug 11, 2012 | Sony VAIO Computers & Internet
Power button is not working on my sony vaio fw21l
if the computer is still in warranty, call sony vaio tech support and they will send an onsite technician to repair the dc in port of the computer.. 888 476 6972 or 239 768 7669
Mar 22, 2010 | Sony Computers & Internet
Changing the LED Screen on a Sony Vaio VGN FW21L Laptop
Do a search on youtube. I've seen many computer repair videos there
Mar 11, 2010 | Computers & Internet
Hello there, There is screws on this that comes loose because of the design and the everyday up and down of the screen. If you email me at tkscw25404@gmail.com I can send you the diagram to tighten these to try it anyways. Thanks
May 27, 2009 | Computers & Internet
I am a PC Technician, I also happen to own a Vaio with this cool but very fragile power button. It will be okay to leave it like that.I had the same issue and I repaired mine because I have experience tearing down laptops. The labor to get to that little plastic piece is extensive. If the situation arises I can explain to you how to do this, ill even have pictures as it is nearly impossible to find service manuals for new Vaios. But it will be fine if it is a little loose.
Feb 18, 2009 | Sony VAIO VGN-FW140E/W Laptop
Tighten the resistance at the hinge of the screen of the Vaio laptop
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't which is the problem know until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Aug 01, 2008 | Sony VAIO VGN-UX280P Notebook
DRIVERS
What Your Actually looking For Are Drivers For The:- VGN-FS485B.
So many people get confused, with Sonys Model And Make Numbers.
Theres usually 1 located Underneath The Base of the Laptop, And 1 On the lower right/Hand/Side Of The Screen Or hinge Cover. ( Differs On Newer models )
The Number on the Screen/Hinge Is usually the Actual Number to search Drivers/Parts et,c For.
If you Go here:- http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN-FS&m=2203
This should lead you to all you require.
Mike @ Compurepair.
Feb 28, 2008 | Sony VAIO VGN-AR230G Notebook
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
1,322 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
