Question about ASUS A8S-X Motherboard
A8S-X Video card issue
The beeps are probably caused by the following discovery! I have looked more closely when removing & reseating the video card (x1950pro) the second DVI output is pushing on one of those nobby things (Capacitor?) What kind of idiot designs a board with a bunch of capacitor thingys in a row at the end of the damn PCIe slot! Arrgh! Check out this pic from Asus and you will see what I mean! http://www.asus.com/999/images/products/755/755_l.jpg Any suggestions?
  • 1 more comment
  • Bernard Noway May 11, 2007
    If you could email me any suggestions I would be grateful... This sites biggest weakness is no ability to directly message the helpful people here!
    my address is psiboy@iprimus.com.au
    Fixed it see the link!
    http://www.fixya.com/support/t147416-asu...
  • Bernard Noway May 15, 2007
    Fixed it by "flexing" the capacitor a little... seems to be working ok for the moment.
  • 3 Answers
Check and see if the capacitor is lose from the board if so get you a soildering gun and put some soilder on it and that should fix you're problem
Posted on Aug 21, 2007
4 beeps and no screen when i turn on my enovo desktop
One long beep followed by three short beeps means that either the video card isn't installed or the memory on the video card is bad. Reseating or replacing the video card will typically fix the cause of this Intel beep code.
Mar 10, 2011 | Lenovo ThinkCentre M55 Desktop Core 2 Duo...
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
Beep codes 1long and 2 short with blank screen
Usually Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
You could try removing the video card and re-seating it. Also you may try using a another power connector than the one you are using as one of them may have a problem. But it looks like a video problem. Check BIOS in case your settings changed and the onboard video (if present) is on. In certain Mainboard it could be a memory issue, reseat your RAM too.
Hope it helps.
Oct 11, 2010 | HP Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
One long beep followed by two short beeps.
That is a video error code. There is a known issue with nvidia/hp video cards. Suggest reading this for more info.
Jul 13, 2009 | HP Pavilion dv6000z Notebook
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Feb 19, 2009 | ASUS A8S-X Motherboard
Bios problem
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
Name:
Email:
Tools for Removing Spyware, Adware, and Malware
PC HELL
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
 1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
Oct 18, 2008 | Computers & Internet
Narly
  1. Clean cooling components that have become clogged with dust. If beeping persists, continue to the next step.
  2. Remove a memory module. If the PC stops beeping, the memory module may be bad, is the wrong type of memory for the motherboard, or was not fully seated/connected. Try reseating the memory into the socket to see if a connection was the problem, otherwise replace the module. Remove each memory module, replacing the one that was previously removed. Once all modules have been checked, if beeping persists, continue to the next step.
  3. If your computer has a graphics card, remove it. If the beep code changes or continues with the same beep pattern, the video card may still be good. reseat the video card into its socket and continue to the next step. If the beep code goes away, the video card may be bad. Try reseating the video card, making sure it is fully locked into the connector on the motherboard. If problems persist, replace the card.
  4. Remove a PCI card. If the beep code goes away, the card may be bad. Try reseating the card into its connector on the motherboard. If problems persist, replace the card. Remove each PCI card, replacing the one that was previously removed. Once all cards have been checked, if beeping persists, continue to the next step.
  5. Disconnect hard drives and CD/DVD drive cables (IDE/ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems persist, the drive itself may be bad and may need to be replaced. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. Once all connections have been checked, if beeping persists, continue to the next step.
  6. At this point, the problem probably involves the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly.
Jun 09, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Beeps
You have an Awared Bios. The link below details what your bios beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
I suggest you remove your memory & re-seat it & do the same for your video card to be on the safe side.
This next link list some basic's about your board.
http://www.pcstats.com/articleview.cfm?articleID=1008
Good Luck.
Mar 14, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
ASUS A8S-X beeps sometimes on startup!
Hi 1 Long, then 3 Short Beeps: Video error The BIOS is unable to access the video system in order to write any error messages to the screen. Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. Remove your video card inspect it for damage and then re insert it. Try rebooting and see if the error remains. If so replace the battery on the mother board and try a different video card. If you have a video card built in then remove 1 srick of the RAM and re boot. Do the same with the other stick. If the error still remains then there is a fault in the Mother Board I hope this helps!
May 11, 2007 | ASUS A8S-X Motherboard
ASUS A8S-X Motherboard Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
