Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag neptne fav 6800 aww does not fill wiht hot water. works fi
I checked hoses. pulled hot water hose, cleaned strainer. still not hot water going into tub.
  • 335 Answers
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
Posted on Jun 27, 2009
  • 3 Answers
Maytag Neptune FAV6800AW, if i select hot or even warm/warm the hot water will flow for 2 to 3 seconds then stop and just hum and vibrate, if i select cold/cold it immediately starts to fill. Any suggestions.
  • 640 Answers
Bad water in let vavle,,did you check for 110 at vavle ,,on hot cycle,,,is vavle humming or vibebrating if not ..replace vavle
Posted on Jan 05, 2009
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Lack of water
First close the main water tap. Then the following.
Check the water inlet hose at the washing machine entering point. You can turn the knob and remove the hose. You will find a strainer attached to the inlet pipe. pull it out and clean the strainer. Replace it the same way. Do not miss the rubber parts. Do not forget to open the tap.
Apr 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My kenmore 70 series is only filling with cold water. The hot water is wide open threw the hose but, it is barely dripping in the tub. Does anyone know what might be causing this and how i would go about...
Check the strainer on the hot valve for debris. If you do not find trash in the strainer you will need a water valve. Less than $12 most of the time
Sep 20, 2009 | Washing Machines
Does a maytag model mah2400a have a drain filter i have a sour smell an have tried vinager bleech and baking soda nothing has worked any suggestions
It has a strainer. These strainers are evidently designed to make washers stink. Your strainer is located behind the kick panel, below the main panel. The strainer is located between the drum and the pump. It is connected to the drum with a rubber hose. Unplug your washer. Pull and clean the strainer, While the strainer is open, look up into the pump suction cavity and remove any loose debris that you see in there. Reassemble the strainer, replace the kick panel.
Clean the door seal face with a bleachy water solution, let it sit, and wipe it down again. You want to get the solution into the grooves behind the seal face, and wherever you think mold and mildew might be on/in/behind the bellows seal.
Put one cup of bleach directly into the washer tub.
Fill all of the dispenser cups with bleach.
Run the washer on your hottest setting (no clothes). I use the sanitary setting with an extended wash.
When the cycle is finished, run another cycle with nothing in the dispenser cups or tub, Just plain hot water, this will flush out the bleach residue. Most folks wipe their bellows seal face and grooves down with bleachy water regularly. (1X / wk).
Hope this helps. Best regards, --W/D--
Aug 10, 2009 | Maytag Washing Machines
My Maytag Neptune does not dispense hot water. Just a trickle. Warm and cold are OK
I'm not a repairman, only a "doityourselfer". Try some or all of the following:
1. Check water valve to see if it full open.
2. Check the hot water hose inlet on the back of the machine. Look for a strainer that may be clogged in the hose inlet (turn water valve off first).
3. Check hose for kinking.
4. With the hose disconnected from the washing machine, try running some hot water through the hose into a bucket just to verify the water is available.
5. With machine set to hot water wash, start a cycle and listen for the hot water solenoid to "click" when the machine is started (some solenoids are louder than others so listen carefully). If water begins to trickle in when you here the click then the solenoid is probably working properly.
May 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Hot Water won't fill
I like to put the hose over in the tub and run some water just to eliminate plumbing problems from that point back. Then, I check the inside of the water valve where the hose connects which you have done. If all this is ok the only thing left is to replace the water valve. I have had some success taking the water valve apart and cleaning it out. About 2 out of 10 will start working but most require replacing.
Jan 24, 2009 | Maytag Washing Machines
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag FAV 6800 leaks while filling
I was finally able to fix our leak. Noticed that when closed the back of the lid bent down a little toward the middle.  That was enough obstruct the water shooting into the lid causing it to spray out of the top a little and leak out the back alot.  Took the lid off, bent it back, and now it works!
Jun 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Bleach/softener dispenser
Try to push a plastic straw through the hole in the dispenser. This hole could be blocked with lint.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
255 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
