Question about Dell Vostro 1700 Notebook
HHD Thanks, did the job. Niall
Want to unsucribed my email add from from facebook
Hi Suzy,
I hope this helps.
(Click the link below)
Many Thanks,
Niall
How to Unsubscribe From Facebook
Oct 09, 2015 | Apple iPad Air
Hi I have a Acer Travelmate 4050. The MB bios does not pick up the HHD. Wen I startup using my Windows XP cd It does pick up the HHD I can then Format and the installation will copy the files to the...
If the BIOS does not detect the hard disk and Windows XP cannot detect the hard disk to install Windows, then the hard disk is faulty.
To get your Acer working agai, you need to replace this hard disk with a new one.
Apr 21, 2011 | Acer Computers & Internet
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device displays the standard green light. I tried connecting the device to...
Most of these problems are associated with an I.C. on the board that governs the HHD. Unfortunately, the chip gets pitted (overheats) on the GaAs and is ruined. The green light (LED) on the HHD will turn on as it is getting power but the main chip that controls the HHD no longer works thus rendering the HHD inoperative.
Bottom line, get a new external drive. Should you get the same model or something similar to what type of electronic hardware you have, you can remove the new HHD and put your old HHD in its place and you will see that all of your data is still intact.
Apr 12, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Error Message???
sound like the hhd is going .
backup all your files to some external hhd or to another computer.
use the Window Xp Cd to reformat eh hhd and reinstall Xp. if the format encounter hhd problem it will stop. in that case, you need to buy a new hhd and replace it. if not the format will go throught, do that twice and reinstall XP.
Jan 14, 2009 | Acer Aspire 5050-3242 Notebook
Franke ecolino
If anyone have service manual or any kind of electrical drawings of this Franke Ecolino Coffee machine please send to
emrah_turkkan@hotmail.com
Dec 18, 2008 | Franke Saphira Espresso & Coffee Maker
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Toshiba Satellite A65-S126 Notebook will not boot
Locating the HHD in Toshiba will be the most difficult. They have put them in several different places in the machine over the years. First try any access panels on the machine (look for a small rectangle shaped panel aprox. 1x3, probably on the side), then check under the keyboard, on a couple of models they put them under the touch pad. It should be in a HHD caddy, that will slide out. The caddy will have at least one screw holding it and there will be two or four screws holding the HHD in the caddy. Also check to see if there is a connector on the end of the HHD, you'll need that. Once you've found it, put the new HHD back in the same as the old one and you there.
Jun 11, 2008 | Computers & Internet
Dell Vostro 1700 Notebook Logo
78 people viewed this question
Alun Cox
