Question about ASUS A8S-X Motherboard
ASUS A8S-X beeps sometimes on startup!
Hi I have an Asus A8S-X mainboard sometimes on startup it gives me one long beep and then 3 short beeps. I Believe this is faulty memory. Weird that it is only sometimes?! I presently have 2 sticks of 1gb each from corsair installed (VS1GB400c3) Any help you could offer would be appreciated! Cheers, Bernard
  • 2 more comments
  • Bernard Noway May 11, 2007
    Thanks JustAskMe,
    I have looked more closely when removing & reseating the video card (x1950pro) the second DVI output is pushing on one of those nobby things (Capacitor?) What kind of idiot designs a board with a bunch of capacitor thingys in a row at the end of the damn PCIe slot! Arrgh! Check out this pic from Asus and you will see what I mean! http://www.asus.com/999/images/products/...
    If you could email me any suggestions I would be grateful... This sites biggest weakness is no ability to directly message the helpful people here!
    my address is psiboy@iprimus.com.au
    Thanks everybody!
    I have managed to "flex" the capacitor out of the way a couple of millimetres and the card is now fully seated!
    Something should have twigged when cpu id only gave PCIe x8 being used with x16 being capable now it shows both values as x16 Yay!
    So far so good have deliberately restarted the machine a coupla times and it's booting flawlessly now!
    Didn't relise there was a chat feature.. cool (my first time here)
    Thanks again JustAskMe & Dinoza
    Oops! JustAskMe should have "Fixed" rating... and be solution number #1. Sigh! I will look before I click next time, promise!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Psiboy, you can actually use the online chat messaging system to directly contact your expert.
Posted on May 11, 2007
  • 29 Answers
Hi 1 Long, then 3 Short Beeps: Video error The BIOS is unable to access the video system in order to write any error messages to the screen. Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. Remove your video card inspect it for damage and then re insert it. Try rebooting and see if the error remains. If so replace the battery on the mother board and try a different video card. If you have a video card built in then remove 1 srick of the RAM and re boot. Do the same with the other stick. If the error still remains then there is a fault in the Mother Board I hope this helps!
  • Shawn  Hartman
    Shawn Hartman May 11, 2007
    I will do some digging on the website and get back to you.
    I wonder if you may have bumped the capacitator and damaged it???
    I agree with you on the design.
    Have you tried replacing the board battery?? If not try that sometimes the easy fixes are the ones overlooked.
    Believe me I DO IT ALL the time no pride here. That's how i learn, from making mistakes.
    I will get back to ya soon.
    Have a great day!!
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
1 long beep and then 3 short beeps
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
It seems to be a graphic card problem, or the power supply not giveing enoug power.
Try to change the graphic card.
If you are useing the onboard graphic, look for bad caps on the mainboard:
If they look like this, the mainboard is dead.
Good luck
Feb 16, 2013 | ASUS P5KPL-AM SE Motherboard
ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
These module does not exist bigger than 1GB.
Oct 15, 2012 | ASUS Computers & Internet
Getting a single beep upon startup, no video signal going to monitor.
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 14, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
Asus mainboard p5gd1 - fm/s motherboard, giving bios fault d0 or d4 Need ot know the bios type and codes list
Are you by chance using a mainboard diagnostic card? Asus use beep codes to indicate different bios issues. I'm almost certain it is the Award Bios used on their boards.
Oct 17, 2009 | ASUS P5GD1 Motherboard
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Feb 19, 2009 | ASUS A8S-X Motherboard
My computer does'nt boot
Check your Cooling Fan. Sounds a LOT like the fan is getting Sluggish and not cooling the Board Properly.
Jan 20, 2009 | ASUS P5LD2 Motherboard
A8S-X Video card issue
check and see if the capacitor is lose from the board if so get you a soildering gun and put some soilder on it and that should fix you're problem
May 11, 2007 | ASUS A8S-X Motherboard
ASUS A8S-X Motherboard Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
