Question about Soltek SL-KT600-RL Motherboard
Connections can I connect a casset tape player to my pc If so how?
  • 416 Answers
Yes you can.. the Mb has a MIC in, get a cable from the local radio shop for a MIC out jack. it will do the trick.
Posted on Jan 02, 2009
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
How do you remove a cassete tape out of a1999 toyota corrola tape player?
take the unit out and remove cover try and manually release mechanism
if not its toast
Oct 17, 2014 | 1999 Toyota Corolla
Ok I have an Onkyo HTS8409 Network A / V Home Theater System - 7.1 Channel, and dvd player and want to know how to connect a equalizer technics sh-GE70 but i dont have a cassete deck
Equalizer is connected in between the deck and the reciever. Deck into the input of the equalizer, and the out of the equalizer goes into the tape input on the reciever.
Sep 26, 2013 | JVC TD-W118 Single Cassette Deck
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
How to record from Casset tape to CD disk? Thank you !
You can do this with your PC. Download a program called Audacity. It's free. With it, you can record audio from your Line IN connector. You'll need to connect your cassette player to the Line in on your PC. Start Audacity, set it to record and play your tape.
If you want to save the files as a .mp3, you'll also need to download the LAME mp3 encoder. In any case, when you have the file recorded, export it as a .mp3 or .wav and then use your CD burning program to create the CD.
Nov 06, 2009 | Durabrand CD-2086 Personal CD/MP3 Player
Cassette tape door won't open - tape inside
your question is confusing.
CD player or Casset tape player?
Jan 22, 2008 | Audio Players & Recorders
Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
Soltek SL-KT600-RL Motherboard Logo
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
