Question about HP Office Equipment & Supplies
Printer won't print
Printer was working properly C4280. Then I replaced my color cartridge (75XL). Indicator said they could not detect cartridge. I reloaded.Then they said they were running an alignment sheet. Then they said there was a carriage jam.I opened back and front -- no paper in carriage. I pressed OK on clear paper jam. Printer clicks and groans. I get new message there is a carriage jam.
  • 2 more comments
  • lzahorik Jan 03, 2009
    You're terrific!! The best! I was skeptical when I first read your solution, but I did as you suggested, using 3-in-1 oil.It took some force to move the carriages on the rod afterward, but I figured I had nothing to lose, so forced it. And voila! I just printed the alignment sheet, and all seems well. Thank you very much. You are no apprentice!!
  • lzahorik Jan 05, 2009
    Thank you for your help. A previous respondent had forwarded the same info, and it worked beautifully! Thanks again for responding -- you're great to take your time to respond. I do appreciate it.
    Thanks for responding.Your plan worked.
  • Anonymous Mar 16, 2014
    carriage jam
  • 378 Answers
Just remove the cartridge from the printer.after removing the cartridge just remove the power wire of the printer from the mains directly so the cartridge carriage remain in the center ,at that point take a greese material and apply it on the steel rod of the printer on which the carriage moves just with your hand try to move the carriage back and front manually and then at the time when you feel the carriage is moving freely with hand just on the printer by inserting the power wire in the electric outlet.and let the printer to settele for 1 minute then as usual insert the cartridge properly.and it will work. thanks.
Posted on Jan 02, 2009
  • machine83 Jan 04, 2009
    thanks for the appreciation.
Will lexmark 17 black inkt cartridge and a lexmark 27 color ink cartridge fit in a hp photosmart c4280 all in one printer and work properly?
Negative, but you may want to think about refilling your HP74/75 ink cartridges for your HP PS C4280's actually quite affordable.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
Jun 12, 2013 | Office Equipment & Supplies
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
I tried to replace an HP 75XL in my CC5580 All-in-One Printer with a Maxitone 75XL cartridge purchased at Costco, and the printer responds that it will not accept this cartridge. Is there any way to get...
Hello, my name is Steve.
And what you CC5580 printer has indicated that the program that created the replacement cartridge, detected a "fault" that is not correctable unless you use a correct cartridge.
Costco and many other independent dispenser/refillers offer a shell company to sell their cartridges. The chance of it working is 50-50.
The best suggestion is to not use these cartridges. But there are others who will tell you to turn-off the Tool box that indicates the level used in the cartridge, YOU really do not want to do this. This will give the printer other issues down the road.
Stick to your regular ink supplier, if this means purchasing OEM (original equipment), or look for a good "dry- toner-type laser printer to substitute you color inkjet printer.
You will be surprised on the cost per page vs inkjet printing .
I hope this helps, Steve
Mar 01, 2012 | HP Office Equipment & Supplies
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
Print cartridges missing or not detected
Are they new cartridges?
If so, have you removed the clear plastic protection strips from the cartridge heads?
Sep 15, 2009 | HP Photosmart C4280 Aio Printer
Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
May 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
Printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
Printer does'nt work with non H P cartridges
It is pretty clear that you have a defective color cartridge. Return it to your vendor for a replacement. You may have some success cleaning the contacts as shown here, but most likely you need a warranty replacement color cartridge.
Bob Headrick, MS MVP Printing/Imaging
Aug 25, 2008 | HP Photosmart C4280 Aio Printer
109 people viewed this question
Ben Johnson
