Question about Nakamichi SoundSpace 5 Shelf System
Can not turn power on
I have my Sound Space 5 on and suddenly it was disconnected from power outlet in the wall. After that it is dead. What can I do?
  • 5,568 Answers
You didn't mention why it was disconnected and this may have only showed a failure that was going to happen anyway. There may be an internal fuse that was just tired but it will require some disassembly if there is no back-panel fuse holder evident.
Most all consumer electronics use a more efficient type of power supply called 'switched mode' (SMPS) and they are fussy by nature. In your case, the supply was probably close to failure and it was only working because it was plugged into AC but now unable to restart.
You might be able to jog it into working again by repeatedly plugging and unplugging the AC and watching for any signs of life. If an LED somewhere on the front panel turns on, leave it plugged in then. This may not work but won't hurt anything either.
Posted on Jan 02, 2009
This is a PEST (Print Engine Self Test) error = Printhead Left jetstack disconnect. The Left Jetstack is not drawing the expected power from the power supply.
Devices sharing the printer's AC outlet or circuit, such as another printer, coffee maker, space heater, may be placing intermittent demand on the AC circuit. This sudden demand creates a momentary AC voltage sag that causes the PEST test to fail. Verify the AC power source prior to replacing any parts for this error. Xerox recommends this printer be plugged directly into the wall outlet and not into a surge protector, battery backup or multi-outlet strip.
If none of these conditions exist, then the printhead is bad and will need replaced.
046K00530 Printhead (8500/8550)
Jan 29, 2014 | Xerox Phaser 8500/DN Printer
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Panasonic Viera plasma suddenly shut off and wont turn back on and when off it has a dark line on screen
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Nov 13, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
We just got a panasonic pt52lcx15 tv from a neighbor the tv works fine turns on has sound etc for about five minuets then powers down and the red lamp indicator flashes for about 1 time every 5 seconds
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 20, 2013 | Televison & Video
Reset factory settings
Hi Harold,
Here is how to reset the HP Photosmart 8250:
Performing a full reset
1. Press the Power button ( ) to turn on the product.
2. With the product turned on, disconnect the power cord from back of the product.
3. Disconnect the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Connect the power cord into wall outlet.
6. Connect the power cord to the back of the product.
If the product does not turn on by itself, press Power button ( ) to turn it on.
Try to print.
Regards,
Sean
May 28, 2013 | HP - HP Photosmart 8250 printer
NO sound or picture, both suddenly stopped while i was watching tv
Hello there,
For clarification of the problem. Is there any sign that the unit is getting power from it power source?
Did you do disconnecting all the the connection and unplug the system from the wall outlet, and test it to other power outlet?
I would like to request to give me more information about the device.
Thanks.
Regards,
micro~
Feb 23, 2010 | Denon AVR-789 Receiver
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 15, 2009 | Nintendo Wii Console
Wii wont come on.
it might sound silly but is the power cable pushed all the way in? if so take your wii to game or similar and ask them to test with their cable on pretence of poss buying a new power lead if theirs works then new lead is what you need
May 19, 2009 | Nintendo Wii Console
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Nakamichi SoundSpace 5 Shelf System Logo
103 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
