Question about Jensen CD4610 CD Player
Need manual for jensen cd4610
Need a manual for jensen cd4610
  • 1 more comment
  • war-angel Dec 01, 2007
    trying to figure out how to hook the input up so i may be able to hook up ipod, or a dvd player
  • Anonymous Mar 21, 2014
    The radio seeks a stronger signal, i need to switch rds off
  • Anonymous Mar 29, 2014
    Make a wire harness
Go to jensen.com and download the manual
Posted on Sep 26, 2007
    President:
  • 1,294 Answers
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 01, 2007
The door for the cd player wonkt open on a Jensen CD4610
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, applied a little pressure and push. The tray should pop open.
Feb 15, 2014 | Jensen Audio Players & Recorders
I have a jensen cd4610 and it changes stations by itself
Hi nicholelawre,
The fault came from a dirty tack switch(channel button) in the front panel. You may spray some contact cleaner to clean the contact from dirt that causing the resistance and automatically detect by the system which caused of the symptom. If the steps didn't help, the switch need to replaced with new one.
Hope I helped you.
Thanks for using Fixya.
Apr 07, 2011 | Jensen CD-2010X CD Player
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Jensen CD4610 CD Player
Auxiliary port location?!?! where would it be?
The yellow wires on back one has a white cap the other has a red cap those are the input wires you need to buy the cord that goes from a red and white RCA jack to a 3.5mm headphone jack
Oct 02, 2008 | Jensen CD4610 CD Player
Car stereo
if u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Feb 11, 2008 | Jensen CD4610 CD Player
Sound
By no means is this a solution, only a comment - Internal Amplifier is bad. Check your wiring before installing another unit.
Jan 12, 2008 | Jensen CD4610 CD Player
Jensen cd player cd4610
check for power on both the red and yellow wires with the key on. If both have power either the radio needs a reset or the radio is defective..
Sep 12, 2007 | Jensen CD4610 CD Player
Fade and balance
Bass, treble, balance and fader are all accessed by pressing in on the volume control knob. Press and release repeatedly to select the various functions, then turn the knob to make adjustments. An owner's manual can be found here: http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1
Jun 10, 2007 | Jensen CD4610 CD Player
Turn on volume
If you go to this link and click on "find a manual" http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1 Page 11 should tell you what you need to know :)
Apr 20, 2007 | Jensen CD4610 CD Player
Jensen CD4610 CD Player Logo
488 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
