Question about Soltek SL-KT600-RL Motherboard
CONNECTING TAPE RECORDER
Can I connect a tape recorder to rmy soltec mb If so how?
    Scholar:
  • 57 Answers
I assume you want to record from a tape recorder/player. If not, leave a message, but it will be a similar cable and connection.
If your tape recorder has a headphone jack, you can connect it to your sound card with a special cable. The headphone connectors are sometimes different sizes. It could be either a 1/8 inch, 2.5 mm or 3.5 mm plug. Your local electronics supply store (Radio Shack?) should have the cable you need. (I'd take your tape recorder with you, if possible.)
Posted on Jan 09, 2009
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
Sep 09, 2014 | Sony RCD-W500C 5-Disc CD Recorder
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
Technics amp to tape deck connections.
Red for Right channel (play). White for Left Channel (play). Yellow for right (Record) Black left (record). The leads should run from tape (out) play to amp in play. Same for the left channel.
Record from tape (in) to Amp (out).
Jan 29, 2014 | Audio Players & Recorders
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Soltek SL-KT600-RL Motherboard Logo
245 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
