Question about Sylvania 6427TE 27" TV
Jack hi we were moving the tv and didn't unplug the cable, well there was no more give and the cable came right out of the tv with the jack housing, it snapped right off the back of the tv. Is it easily replaced?
    Scholar:
  • 51 Answers
Yes, this is an easy problem for a technician to repair, especially if you still have all the broken parts. If nothing else, he can simply install a new jack anywhere on the back of the TV - if he has to order the exact replacement part, it will increase the cost dramatically and take much longer. If you're okay with a quick fix that "will work", anyone handy with a soldering iron can fix it.
Posted on Jan 02, 2009
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
My TV is connected to cable. I want to connect a VCR to the TV....how?
You didn't give model numbers.... But for most equipment: hook the VCR to the TV's Yellow, White, and Red jacks using a composite video cord. Or if both have screw on Co-Axial type cords:
cable in to VCR's ANT IN, TV OUT to TV's IN.
Jul 03, 2011 | Televison & Video
The power went off today for unknown reasons at my house while I was watching my LG TV through my LG LHB335HTS which is hooked up with HDMI Cables. When the power came now it will not show a picture...
I was able to fix this issue by changing the screen resolution to auto on the home theater system. Since I had no picture on my tv, I had to unplug it and plug it into another tv. Once connected to the other tv, I was able to access the menu and change the resoultion to auto (it had been reset to 480dpi, this is why it didn't work on my main tv). After I set it to auto, I was able to get it all to work. My niece had been playing with the button in front of the device and apparently the sequence of opening the DVD tray and pressing the stop button causes the screen resoultion to reset to 480dpi.
Jun 16, 2011 | LG LHB335 Theater System
Can't them to work on my tv after plugging them into the 3.5mm audio out jack
Excuse me if I'm sounding a bit dumb, but don't these speakers need to be powered by an external power supply (You didn't give the model but I'm almost 100% sure they do). if so are they connected to power? And if they are (again, you didn't give the make and model of your TV) are you sure it's an output and not an input jack?
Simple things of course but sometimes overlooked.
Regards,
Mikeywaf
Apr 21, 2011 | Insignia 2.1 Speaker System (3-Piece)
Connected to LG TV and getting "no signal" on
Verify that you're on the right input on the TV (Video 1, Video 2, Component 1, etc.).
Also verify you didn't plug it in the output jack behind the TV, you need to plug the cables in the Inpout jack.
Apr 19, 2011 | Sony PlayStation 2 (PS2) Console
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Coby DVD player set up
Brenna,
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Zenith system 3 tv will not turn on
I'd say just get a stereo system (amplifier) or something like that, and hook your cable box, vcr, converter or whatever you have right into that. That's what I've been doing for years. Most cable boxes and satellite boxes will control the main volume that goes to the sound output, or you can get a digital stereo with a remote to control the volume that way.
Oct 26, 2006 | Zenith SY3538RK TV
Sylvania 6427TE 27" TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
