Question about Cuisinart Cup-O-Matic SS-1 Coffee Maker
Cup-o-matic won't work
My Cup-o-matic acts like it's warming up and getting ready to brew, but it ends up just beeping with the on/off button flashing. It has happened periodically before, but I could always get it working. The little float in the reservoir isn't stuck (it's floating), so I don't think it's mistakenly thinking there's no water. The coffee/pod holder is also pushed all of the way in. Anything else I can check?
SOURCE: coffee maker beeping
ugh! This just happened to me. washed it all out - let it sit - plugged it back in and now it beeps.. and ONLY beeps. whattup?
Posted on Feb 01, 2008
SOURCE: Cuisinart 12 Cup Digital Thermal Coffemaker
I called Cusinart support and they told me to fill with 2 cups of white vinegar and the rest water, let set for three hours. Did that. Had to keep hitting the on button to get this solution through. Then used a solution of one cup of vinegar and water and this ran through the whole cycle. Ran three more with just water and now it works just fine. Brewed coffee this morning with no problem. Didn't think this would work but seems to have solved the problem. They do suggest you decalcify once a month using the vinegar solution...hope I remember to do this as it would be a lot easier than having to get hitting the on button. Good luck!
Posted on Mar 01, 2008
  • 4 Answers
SOURCE: One year old coffee maker won't brew
I had the same problem, only this happened on the last 3 dcc-2000 I purchased. I called customer service today, and they informed me that there is a 3 year warranty on this product. Wow... This time they really helped. I have made 2 phone calls to customer service, and was put on hold for over 20min. each time they found out what machine I was calling about. Call customer service, and don't give up!
the number is 1-800-726-0190. you will need the serial # from the bottom of the unit (stamped in) and the model #.
good luck! Bob
Posted on Jun 10, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
My mr coffee optimal brew just beeps constant when you press the brew now button
My hubbub and I "downgraded" to an "upgraded" Cuisinart to Mr. Coffee Optimal Brew 12 cup carafe, mainly d/t the carafe keeping the coffee hot with no burn taste and the stylish st. steel carafe. We've had 2 cuisinart's and both gave us leaking issues after 3 years of hard use (2 pots daily). The cuisinart leaked and also had the burned coffee taste, We unpacked the Mr. Coffee, cleaned all parts, after several attempts, finally stopped beeping and ran the first clean cycle. We are past ready for a great cup of joe...NO.pot ready, grounds in, attempt to turn it on and...that beeping almost got and may still get this apparatus taken back, traded, gone....but after reading my book that never says a word about beeping, I googled and saw MDLS1 replied and while I thought it was crazy I was not giving up without pulling out crazy, and it worked. After a solid hour, I found an answer... You can't just tap it here and there, I took resevoir off, banged it good, forceful but not to hurt my hand, took the basket out and banged the top and clapped around all sides, filled her up, turned it on and walla.made a perfect 10 cup = about 5 "normal" cups of joe, and it was good...pot made in 8-9 minutes, stayed hot over an hour when it was finished. Tonight, I have a hot cup, hubbub got his,and we are happy campers...however, one more beep and it's gone.
Dec 06, 2013 | Mr. Coffee 10-Cup OptimalBrew Thermal...
I turn on my Mr. coffee maker and it just beeps and won't brew any coffee. What could it be?
Tried to clean it, everytime you press the brew button it just beeps and if we try to set it to clean it sounds like it tries to turn on but nothing happens.
Apr 27, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart coffeemaker won't brew
A common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again.
Nov 01, 2017 | Cuisinart Coffee Makers & Espresso...
Coffee not hot enough
hi elite 288! have you tried pre-heating your coffee cups? i fill w/hot water, then set them on cup warmer until i brew coffee (dump out water & slide cup under spout at last moment) and i do my frothing of milk before brewing espresso. also, have you allowed adequate time for machine to warm up/run just water through machine: after it indicates it's ready to go, hit the brew button & allow about a 1/2 cup or cup of water to run thru, warming up the brewhead. when ready button again lights up, brew your espresso. if this doesn't get it hot enough for you, try descaling your machine (you can look online or in manual for how to do this). since you have a refurb unit & heating element may not have been replaced, it could have some build up on it causing it to heat up all the water less efficiently. if this doesn't work, you may need to have the place you purchased it from diagnose and repair. good luck!
Jan 11, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Cup-O-Matic SS-1 Coffee Maker Logo
79 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
