Epson Stylus CX5400 All-In-One InkJet Printer
Problem for Epson Stylus CX5400 All-In-One InkJet Printer
Error massage not compatible ink cartrage when using ciss supply
By rcapucao on Jan 02, 2009
We've converted our Epson CX5500 to CISS. This worked well until recently when the two red lights started blinking. Our ink supplier sent us resetting program which we tried. The server we were using could not detect the printer. When we connected it to another pc we were able to complete the resetting procedure. The technician also attached a waste ink tank. The printer worked for a day or two and now it's not working again. Is it possible that there's a problem with the hardware itself? where can i download a resetter software for my printer cx5500 w/c i used a ciss ink supply.
Same Problem
Feb 02, 2009
-   The cx 5500 is rubbish, it's install disk also has spector keylogger on it which is spyware.
Add to it the problem that it wont work unless you use genuine ink cartridges and you know it's rubbish.-   Guest
Solution #1
posted on Oct 08, 2009
Not Rated)
anyone516
Rank: Apprentice
Rating: 0%, 0 votes
The problem here is that Epson actually programs the hardware to recognise if you are not using genuine ink cartridges and the malfunctions you are experiencing are programmed malfunctions, they are not random faults. The .PIF file on the install disk is indeed infected with spector keylogger although after being contacted, epson denies this is true. Spector is very hard to find and was designed to remain hidden at all cost and is the height of keylogger technology even to this day.
Sadly, several versions of epsons' printer/scanners are infected and it appears to be everything made after 2005.
The net is rife with the known problems of epson ink whick appears to be the cheapest on the market but the usuage percentage is in reality much higher than other printers.
My advice is not to buy Epson products, they are unreliable and unsafe.
Was this helpful?
Yes
No
Solution #2
posted on Jan 05, 2009
Not Rated)
asson
Rank: Apprentice
Rating: 0%, 0 votes
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus CX5400 All-In-One
Questions and Unsolved Problems for Epson Stylus CX5400 All-In-One
Do you recommend Epson Stylus CX5400 All-In-One InkJet Printer?
Answer
Answer
Epson CX5500 cartridge error led blinking always I have also change all the cartridge with new... (More)
Answer
I cant find any instructions on how to scan with my epson bx300f? I want to scan old photos then... (More)
Answer
my pinter does not pint well , it sucks the paper and it shots it uot ,but it prints afther giving... (More)
Answer
The piece of black foam that sits on top of the print heads has torn and now it won't print... (More)
Answer
Have a Epson Stylus CX5400. Have opened lid and replaced ink cart. while looking insided, noticed... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , GA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
