Question about Ricoh Aficio 1022 All-In-One Laser Printer
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Normal
0
May 25, 2016 | Office Equipment & Supplies
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Apr 01, 2014 | Ricoh Aficio 1232C Color Copier
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Mar 27, 2009 | Ricoh Office Equipment & Supplies
Mar 20, 2009 | Office Equipment & Supplies
Jan 09, 2009 | Office Equipment & Supplies
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Nov 28, 2008 | Ricoh Aficio CL3500N Laser Printer
421 people viewed this question
