Question about Arris Touchstone 450a (CM450) Modem
Phone went out
I accidentally knocked a drink over and it spilled on the floor i think it may have splashed up on the router but its not fried obviously because im on the internet and i have cable TV i need to know what i can do i have tried the "hard reset" i tried disconnecting it i let it sit overnight and still nothing i dont know what to do. any ideas anyone. i cant call armstrong because i dont have a cell phone is there any support i can get online?
  • 37 Answers
If you need to clean the router, distilled water baths can help... thats what all the components get before assembly. They use a LOT. I have done this to other objects with varied success proportional to my effort to acquire distilled water and cleaning and then drying internally as best as possible then using say a hair dryer to make completely dry.
Posted on Apr 19, 2009
Stuck in 4 low replaced switch after spilled drink fried it and wire's
will all that needs to be replace, its not damaged.
what is the question. here>?
Apr 19, 2015 | 2005 Jeep Grand Cherokee
My kids accidentally spilled orange juice on my laptop. It continue to work for a little but now the screen is black. What can I do?
Sugar is the worst. If you had immediately unplugged and removed battery you may have had a chance. Once sugary drinks get in it's almost a death sentence for electronic devices. If it's valuable take it to a Qualified Computer Tech, if not right it off as a learning moment. If you want, this is a detailed explaination: http://www.guardian.co.uk/technology/askjack/2012/jul/05/drink-spilled-on-laptop
Apr 29, 2013 | Acer Computers & Internet
I accidentally splashed water on my phone. All
I think there is still water inside your phone that is affecting the charging port.
Follow this step if you can.
First Get your set of screws to loosen your phone,
remove the panel which is the same as the board of the phone,Get a brush and a methylated spirit, apply some methylated spirit on the panel (a little), brush gently and after brushing, live it to dry up a little and fix it up back.
After doing that the phone is suppose to work normal back.
If it didn't charge, then replace your charger.
good luck.
Mar 09, 2010 | Cell Phones
Trac off + engine light is lit on my dash. About a
Usually when you have a traction control problem and the engine light on sounds more like a sensor issue. If you have just had the brakes replaced maybe they messed up the abs sensor which is in the wheel well area.....which could have the effect.
Aug 18, 2009 | 1999 Lexus ES 300
Flap on ice dispensor does not close.
The flap is probably gummed up with sugar from filling glasses with sugary drinks in them. When the ice drops into the glass it splashes the drink into the chute. It needs cleaning.
Just flushing plain water over, under, around and through it will probably free it up (yeah, I kow it's going to be messy).
May 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
I accidentally knocked a drink over and it spilled on the floor i think it may have splashed up on the router but its not fried obviously because im on the internet and i have cable TV i need to know...
You might try unplugging the phone from the phone port and plugging it back in several times to clean the contacts; this may be the only problem and may have happened as a coincidence, not having anything to do with the spilled drink. Also perform the "cleaning" where the wire plugs into the phone. If this still doesn't solve your problem, try another phone cord. If still no luck, you'll probably need to replace the router - these are not economically repairable. Naturally, if you see any sticky matter on the plugs, then clean them with rubbing alcohol, as well as swabbing the inside of the ports with an alcohol-soaked Q tip. It's best to have the unit powered off when you do this.
Jan 02, 2009 | Arris Touchstone 450a (CM450) Modem
Jasjar-no sound-after spilled water on it.
I think you still have a good (not 100%) chance of saving it. It usually takes much longer than 1 day to dry out electronics that are still intact. I would open it up and let it dry. Otherwise, see if have a nerdy friend who has access to a non-humidified incubator and leave it in there for a few days. (that's how I salvaged a phone that went through the wash!)
Aug 31, 2008 | i-mate JASJAR Smartphone
Laptop starting issue
Did you spill the water while you were using it or turn it on shortly after the spill? If so, you fried something. It's electronic, it doesn't mix with liquid at all, you're lucky you don't have a nice expensive door stop, use a bottle with a screw on cap if you absolutely have to have a drink while working with your laptop. Also it takes days, if not a week, for a laptop to completely dry out inside, a dryer isn't going to do much good unless you take it apart. Either deal with the issues or take it to a shop and have it diagnosed. It's going to be a hardware issue consisting of the motherboard.
Jun 22, 2008 | IBM ThinkPad T42 Notebook
A drink was accidentally poured on the floor this afternoon and lo and behold my phone was by it.there were signs of the drink entering the screen.as i tried sucking out the drink from parts of the phone...
drink might have entered into your phone so that there might have been short cicuit taken place inside it ........so better take it to near by service center to check it
Jun 20, 2008 | Cell Phones
Arris Touchstone 450a (CM450) Modem Logo
119 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
