Question about HP Pavilion dv4000 Notebook
Window will not boot up
I have an hp dv4000 the it was working fine yesterday, but today I tried to turn it on. It shows me the windows screen (i have windows xp) but will not boot up to my desktop. I tried everything it won't even boot up on safe mode. It dosen't shut off it just will show me a black screen. What could this be?
  • 1 more comment
  • my5kidss Jan 02, 2009
    I tried all of this but computer is not responding and keeps shutting down after it shows windows it will not load to the desktop
  • Dan rogers
    Dan rogers May 11, 2010
    did you try to boot with the cd the computer came with?
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    have you set the boot sequence to cd,floppy,hdd settings in your bios?
  • 238 Answers
One of your system files of your windows installation has been corrupted that makes your windows not to go through your desktop. Reinstalling your Windows Operating System will cure this. You don't have to install a fresh copy of your windows but just to repair it. Repairing your Windows installation will repair your corrupted and missing files of your previous installation. No worries to think about because your saved files in your hard drive will not be removed/deleted.
Posted on Jan 03, 2009
  • 520 Answers
IT DOESNT MATTER WHAT SEQUENCE IF BIOS CANT FIND 1ST DEVICE IT GOES TO NEXT AN SO ON,
TRY THIS.BOOT UP GET A FAR AS YOU CAN GET THEN PRESS AND HOLD THE POWER BUTTON(ABOUT 5 SECS)
THEN REBOOT.
IF THIS DOESNT WORK BUT YOU CAN GET TO THE WINDOWS SCREEN PRESS CTL+ALT+DEL AND CHOOSE LOG OFF THEN IN NEW SCREEN SELECT LOG ON.
IF THAT DONT WORK REINSTALL OS NOT REPAIR.
WHEN YOU GET TO THE INSTALL PAGE SYSTEM SAYS OS ALREADY INSTALLED CONTINUE TO INSTALL OR REPAIR .AT THAT STAGE EITHER CARRY ON AND INSTALL FRESH COPY OR REPAIR.
Posted on Jan 02, 2009
  • tat4u
    tat4u Jan 05, 2009
    if you can boot from os disk repair by all means,but there a method.when you start from boot disk it loads and states install or repair .if you choose repair at this stage it will go to a dos platform(c:/promt) and expect you to know how to repair which in most cases people dont.
    so you choose install and after system diagnose it informs you that theres already a os installed ;install or repair.it is at that point that you choose repair.if you cant install from disk eg only get so far and stops.first of all restart goto setup(bios)
    choose reset to default.save settings and exit.
    if you still have problem could be you hd has bad sectors.let me know and we'll go from there.Also get hold of some software called spotmau (download free version) when downloaded open the files and write to a created boot disk (instructions in package)
    startup with this disk and you will find with its programs any problem you may have preventing you from access windows.
    if it turns out that your hd is damaged spotmau will repair it depending on how damaged.spotmau works in dos so only needs first 64k mem no sys drivers or any access to hd which is why it can do what its capable of.
HP pavilion dv3 notebook is not booting. its new one. yesterday i format it & it was working perfectly yesterday. but today when i try to start it. its flashing but not showing any dispaly. i am unable...
Definitely a problem occurs in the booting sequence.
I'd suggest to re-install the operating system (I assume it's a Windows) one more time. Once the system is installed reboot your notebook and see if restarts properly. If so, go on CONTROL PANEL and choose to make a RESTORE POINT at that time.
If the REBOOT option fails that means your Hard Drive might be faulted or the BOOT MANAGER in Windows is not working properly.
But if the REBOOT will be just fine and if you did a RESTORE POINT I'd suggest you to be more carefully when you will start installing the third party software on your notebook. Some softwares might interfere with your Windows drivers and might modify those drivers.
Mar 02, 2011 | Computers & Internet
My HP a800n (using XP) worked fine yesterday. Last night, an automatic update came in from Microsoft. Today, I cannot get it to consistently boot up. It did it once earlier and locked up. Now, I get the...
Try to boot up into safe mode and see if you can get in there. If so then go into the system tools folder in the start menu or by going into the windows icon. You would go into accessories and then system tools and then go into system restore.
In the system restore choose the last good known date that is bolded when the computer was working properly. After you click on the date to choose it go ahead and let it restore. It will need to reboot, once it does if it goes back in then your good. At that point I would suggest turning off automatic updates for windows.
If you can't get into safe mode, then your going to need to reinstall windows cause the operating system is corrupted.
Apr 15, 2010 | HP Pavilion a800n (PP163AA) PC Desktop
Scrren Goes Blank after the booting
Hello. Put your primary boot to hard disk.
Feb 22, 2009 | Toshiba Satellite M115-S1061 Notebook
My laptop will not boot up
Try soft resetting the laptop .
1. Disconnect the Ac adapter
2. Remove the laptop battery
3. Press and hold the power button for 10 seconds
4. Reconnect the power adapter only and power on .
5. If the laptop starts fine , reinsert the battery back
Thanks
Proton
Jan 10, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 display dies b4 it even boots
When you get to the normal/safe mode screen, select enable VGA. This will boot your computer using the standard 640 x 480 default. Once you are in windows, then you can go into the display properties and change it to a resolution that is compatible with your screen and computer.
Thanks and pelase take a moment to rate as fixya.
Nov 08, 2008 | HP Pavilion dv4000 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 turns on and shuts off and turns on and shuts off -
No I work on HP's all day, it is nothing to do with the OS or the BIOS. It is a problem with the motherboard fan control, in other words the mainboard is bad even with the latest BIOS update. The CPU is getting too hot, as this happens the CPU gets damaged because the Fox board does not have a temp sensor. So periodically the voltage make kick on the cpu but for the most part the computer will never work the same. The longest I got this dv4000 to run was just under 4 hours with no apps running.
Total overhaul replace board, processor, and possibly the fan.
~Hope this answers your question.
Apr 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
225 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
