Question about Mitsubishi WS-65809 65" Rear Projection Television
My mitsubishi ws-65809 will not power up.
The green light comes on for about 2 seconds then I hear a click and the light goes off.
    Genius:
  • 1,239 Answers
It is a power supply problem. Try unplugging it for 5 minutes and turning it back on. Also if you were having problem with any picture issues it is the convergance, and that requires chip replacement.
Posted on Jan 07, 2009
  • 67 Answers
 if you were having problem with any picture issues it is the convergance, and that requires chip replacement. They are estimating $350.00 to replace the power supply.
Mine is doing the same thing. I just talked to the repair guy. It is a power supply problem. Try unplugging it for 5 minutes and turning it back on. Also if you were having problem with any picture issues it is the convergance, and that requires chip replacement. They are estimating $350.00 to replace the power supply.
Posted on Jan 02, 2009
I have a mitsubishi model ws-65809. i press the power button the green light comes on then it shuts back off.
IF YOU have unplugged it plug it back and try to turn it on, when green power light goes out:
On the front of the set press and hold BOTH the menu and input buttons at the same time--hold both for at least 5 seconds and release both.
This is the self check this set has: power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
The 2,2 error code is the most common and is short protection and I know if that code how to fix the set---for many customers it can be a do it yourself fix with parts cost under 35 dollars total.
Let me know what code you get and I will try to help you.
Fixed over 1,000 of these Mitsubishi sets.
SD TECH
Mar 24, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Green powere lights comes on and goes off.
Do the self check this set has, when green light comes on and goes off, on front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and repeat it several times.
Let me know what error code you get and I will tell you what it means.
SD TECH
Jan 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv will not turn on manually or with remote
you need to get the stk chips replaced. i had it done with mine, it cost me 411 dollars for a tech to come do it. it worked fine for about 4 months now, and my red color is gone. mitsubishi sucks, sorry : (
Sep 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS 48313
Geometry correction should be your problem. May cost you3-400.00, but you do need professional
Craig www.clastorations.com
Jun 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
