Question about Belkin N Wireless Modem-Router F5D8633au4A
When trying to use my wireless router it keeps disconnecting and re connecting itself. had to revert back to old wired router at mo, fustrating because wanted the freedom of wireless laptop useage.
  • 192 Answers
It may be the seting on that laptop for the wirless adapter might not be set to the highest setings that you need to get a better conecsion. If you think this will help you i will post a comit with diresions to do this proseduer.
Posted on Jan 05, 2009
Wireless connection keep dropping every 10 15 mint, but the direct (wire) stay connect ?
check channel , try to change channel to 6,11 . check the long way between your device and router . if not soluted , try another pc to check disconnection , if disconnected the problem with your wireless router , if not the problem with your wireless device
Sep 05, 2013 | TP-LINK TL-WR740N Router
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
What is the operating system on your computer?
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
The router keeps cutting out(every 30 mins or so) and I have to keep rebooting by disconnecting and reconnecting mains
theres something interfering with your connection most likely its to close to your main internet connection and then again it might be because your to far away from the router if that dont work try and delete the router software data and reinstall it some times the files arent work great like they should and may be haveing dificulties trying to process the connection to establish it properly. I hope this helps.
Dec 31, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My wireless on desktop sometimes disconnect itself on xp why is that and how can i make it automatically put it back right after? by itself?
I've had this same problem. You must get a new router because routers, especially if they're old, have connection/bandwidth technicalities which cause them to malfunction at times.
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
My thinkpad keeps reverting back to an old IP
go to your prefered wireless networks and delete the old entry this way it can not revert back to it
Jul 12, 2009 | IBM ThinkPad T40 2373 Notebook
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot acquire network address from access point
then it seems thatb the wireless security key for your network is incorrect, make sure if you are entering the key correctly..
or else..
check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Dec 02, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
Nov 27, 2007 | NetGear WGT624 Wireless Router
Belkin N Wireless Modem-Router F5D8633au4A Logo
78 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
