Question about Epson Stylus CX5400 All-In-One InkJet Printer
I have a problem w/ my printer w/c i used a ciss ink supply i used it for a year but suddenly 1 weak ago i cant finish a print for 1 page cause it has a problem it says out of ink.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Tip
Ciss and refillable cartridge systems
Depending on printer brand and model, there are lots of ciss (continuous ink supply system) solutions to buy.<br /><br />Bare in mind, though, if you are planning to use printer heavily, there are other considerations you should think about:<br /><br />1. If not used regularly, an air bubble may occur and it takes a while to pop it up. Also ink may dry in certain area and it's a mess to resolve.<br /> <br />2. The ink supply (depending on supplier) may not be good as the original; color depth and durability wise.<br /><br />3. Cartridge recognition problems may occur from time to another, so it must be removed and inserted again.<br /><br />4. CISS system usually have a chip to fool the printer and it may fail with any liquid contact.<br /><br />5. ink pad inside printer fills quickly on heavy use, thus its wise to direct the pipe into an external tank (found inside and in the back of printer for Epsons) <br /><br />In conclusion, if you intend to have more than 100 pages/month, consider compatibles or refillable cartridges. ciss is good for +200 pages/month.<br /><br />e.g. (epson rx685 blanks out all 6 cartridges except for the black after 10x15 photo's in with high quality enabled)<br /><br /><span style="font-style: italic;">Please note that these tips are based on experience with 4-6 cartridge systems for Canon and Epson printers.</span><br /><br /><br />If you find this informative, kindly <span style="font-weight: bold;">vote positively</span> for me to continue sharing. Good luck and thanks.
on Nov 26, 2010 | Office Equipment & Supplies
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
Im using ciss for my epson cx3700 and the magenta wont print anymore
Make sure there is not an airlock in the magenta ink line. This is best achieved by fitting a syringe to the flow line and sucking through some ink. Also you may be able to use a syringe and needle to inject some in into the cartridge to prime it. You may need to run several cleaning cycles to get the ink through - I had a similar issue with and Epson R300 using CISS and carried out over 10 cleaning cycles to get the yellow ink to flow again. It may also be worth removing the cartridge and leaning the exit area with a cotton bud soaked in isopropyl alcohol as residue can build up in this area. If the problem persists you can fill the cartridge with cartridge cleaning fluid to flush it through and then empty it and reconnect the CISS ink supply. If you disconnect the CISS Supply a good tip is to use a bulldog clip to prevent the ink from siphoning out of the supply line while you are attending to the cartridge.
Oct 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson CX5500 with CISS ink supply not printing
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Jun 19, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printer stopped working ;printer error
Sounds like you have a faulty printer. I use both Safari and Firefox without any problems [Epson CX9400Fax]. Call Epson and if your still under warranty they'll send you another one or pay for a repair. Do not pay the repair yourself as you can buy a printer with a 1 year warranty from Epson from their Clearance Center. BTW, I've been telling everyone to buy a CISS system as it saves tons of money on ink. http://www.inkproducts.com/ink-store/
Apr 24, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Error massage not compatible ink cartrage when using ciss supply
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Jan 02, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Both Red Lights Flash together green light off - no printing
Mine did that too but my power went out in the house.
So diconnected it and uninstalled ssc utility.
Then reinstalled.
Worked fine after that. Hope it works for you.
Dec 26, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
