Question about GE GSC23LSR Stainless Steel
Part replacement. I have a electronic board on the back of the fridge that has a bad capacitor. Where can I find a replacement board? The model is a GE GSC 23 LSR, in stainless.
    Sergeant:
  • 311 Answers
You can use links from our fixya site or google you brand or model#
Posted on Jan 02, 2009
Irritrol rd 900 lcd flashes 5en and system will not water.it fails in manual,semi,and programmed
There was a bad batch of capacitors that came out of China a few years back. All of them eventually blew and caused many different electronic devices to fail. The capacitor is a round can on the electronic board. If the dome is rounded, it is bad. If they are all perfectly flat, they are OK. Check all the capacitors. Since the power pack is 24vac, the RD900 will certainly have at least one capacitor on the board. If bad, it can be unsoldered and replaced.
Jun 02, 2014 | Computers & Internet
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
I HAVE A KITCHEN AID MODEL NUMBER KSRA25FKSS00 and it is not cooling
have you replaced the ptc overload/relay on the compressor,as this is the actual start and run component that the compressor needs or it wont start or run,remove it by unplugging it off the compressor and a good sign if its bad is it will sound loose like pieces loose inside the ptc unit,you should also replace the run capacitor connected to this component too
Nov 29, 2012 | Refrigerators
Model # HL32D1 Haier LCD TV Wont power on i tried puling plug and plugging back in This happened like 2 weeks ago but came back on now its doing same thing"
Tv have problems with it power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or u have all the tools also can do basic soldering and u know basic electronic too?Yes,check the whole power supply board carefully for dying and dead capacitors parts.These capacitors parts alway bulges up or puffing up onto it tops.Replaced all these dead bad capacitors components parts,should get the tv power back to the tv unit again for good.
May 24, 2011 | Haier HL32D1 32 in. TV
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
May 09, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a Samsung LCD TV and it won't turn on
Hello! Just check your main power supply socket. If it is ok than just open your tv back cover and check the fuse. I am sure the fuse is burnt. If the fuse is also ok than you need to consult a technition. But mostly it is the problem of burning fuse
Apr 04, 2011 | Televison & Video
Monitor goes black on screen while using The only ay to bring it back up is to turn it off and back on
There is a problem with the backlight controller inside the monitor. It may be due to bad capacitors or the inverter transformer may be faulty. Bad capacitors can be replaced or you can replace the backlight inverter board with a universal inverter board if you have some electronics knowledge.
Mar 01, 2011 | Computers & Internet
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
Honeywell fridge model 88031. Power cycles when plugged in. Light flickers and fans stutter but do not start. Appears to not be geting enough power. Suspect control board (or a resistor/capacitor) has...
Here we go folks, the problem is a failed capacitor on the circuit board.
It is called C10 which is printed on the circuit board, it is located on the left side of the silver heat sink and above the doughnut shaped coil, you should replace it with the same or one catagory higher in voltage.(1000 mircofarad 16 Volt)
You should have some soldering experience to replace and please pay attention to the polarity. (Pos and Neg.)
Fuji
May 06, 2008 | Refrigerators
GE GSC23LSR Stainless Steel Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
