Computer loading/splash screen pixilated and distorted
I am running XP Pro, service pack 2 on a AMD Athlon 64 bit 3000+ 2.01Gh with 2 Gigs of Ram.
This is a new problem that just developed when my 10 month old grandson decided to give my computer a hard reboot.
The American Megatrends screen with all the computer information, and the XP loading/splash screen boot up all pixelated and distorted. At this point it would be impossible to read any text to enter the bios should I need to.
The screen is back to normal and perfect once the log on screen comes up, but everything before that is messed. There are no problems booting, it is just the first initial loading screens are a mess. Any ideas would help, I can give a link to a screen shot if needed. Thanks in advance
  • 2 more comments
  • jessie292 Jan 02, 2009
    Yes, after logon, everything is normal, games/video's/music all run perfect, desktop is all normal, computer runs a bit slow, but i dont think that is associated (I could be wrong). The only problem I am having is the loading screen,
    I have a VisionQuest 22 inch auto adjusting monitor, it worked fine with this computer for 6 months or more, this is a very recent problem that occurred after an accidental hard reset. But I will try your suggestions and let you know.
    Ok, in this order, I tried:
    Hooking up to different monitor, rebooted: no change
    Resetting current monitor to factory defaults, rebooted: no change
    Reinstalling video drivers from disk that came with computer, rebooted: no change
    Updating current video drivers, rebooted: no change
    Here are links to screen shots that I took, I hope this helps with description of what is wrong.
    http://www.sfsdd.net/Jessie/misc/Screen1...
    http://www.sfsdd.net/Jessie/misc/Screen2...
  • Dan rogers
    Dan rogers May 11, 2010
    after the distortion can you log on and use the computer as normal?
    Master:
  • 413 Answers
If you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
Posted on Jan 02, 2009
  • Dan rogers
    Dan rogers Jan 02, 2009
    im just wondering if the hard reset might have messed up the settings memory in the monitor is basically what i'm getting at. It is doubtful but somewhere to start
  • Dan rogers
    How is this monitor hooked up to the computer? Are you using the standard VGA 9-pin trapezoid or the newer DVI plug kinda rectangular many pins?
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
I want to add more RAM. Is it possible?? Worth it??
It Depends On How much ram you are running now. More ram is Always A good Thing.
However, The Amount of Installable Ram Depends On the Operating System you are running.
Windows XP, Vista, and 7 32 bit (x86) systems only except up to 4 gigs of ram. (Sometimes 3 1/2)
Windows XP, Vista, and 7 64 bit (x64) Systems will except up to 16 gigs of ram. (Some Beyond that)
If you are Unsure which System you are running,
1. Click on the Start Menu
2.Right Click on my Computer
3.Doube Left Click on Properties
On the Main Properties Page it should display
1. Which operating System you are running and Which bit it is (eiter 32 or 64)
2. How Much Memory (RAM) you are currently Running
3 and What Proccessor is Installed in your computer
Jan 18, 2011 | Gateway 3522GZ Notebook
Umm the info on one of my appliances is wrong and have no ide a how to edit iton this website by the way it's a 3 gig ddr2 about to be a 4 gig apparently that's the max the motherboard will allow even...
If you have a 32 bit version of Windows dont put in 4 gigs. The Motherboard may support it but a 32 Bit version of Windows will only support a total of 4 gigs of ram including the video memory, cache, and pci. If its a 32 bit I normally recommend no more than 3.5 gigs of ram memory. Normally its safer to run 3 gigs. Windows may not run well if you go past that 4 gig point. As far as the appliances problem your refering to I didnt understand what you were asking for.
Hope this helps keep you from having a ram issue.
If you need help with the other question please be more specific. Thanks...
Sep 23, 2009 | Gateway GT5453E Refurbished AMD Desktop...
How can I get the SP-1 service pack from MS to load?
Go to this link and save the file:
http://www.microsoft.com/downloads/thankyou.aspx?familyId=b0c7136d-5ebb-413b-89c9-cb3d06d12674&displayLang=en
If you can not download it from the Vista computer, try to download it from a friend's computer and save it to a thumb drive or burn it to a CD. This is for the 32-bit Vista Operating system. If you are running the 64-bit OS (don't just go by your Processor that is 64-bit, but your actual Windows Vista operating system), then go to this link for the 64-bit version:
http://www.microsoft.com/downloads/thankyou.aspx?familyId=874a414b-32b2-41cc-bd8b-d71eda5ec07c&displayLang=en
Hope this does the trick!
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
1394 Controller trouble
What service pack is on it? What does event viewer say?
Nov 22, 2017 | Gateway GT5426E Refurbished AMD Desktop...
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
COREL x4 running very slow & spooler problem
System Requirements:
Processor:
# Pentium III, 800MHz or AMD Athlon XP
Operating System:
# Windows XP with Service Pack 2 or later
# Windows Vista (32-bit or 64-bit editions)
Hard Disk:
# 430 MB
Memory:
# 512 MB RAM
Optical Drive:
# DVD-ROM
Other:
# 1,024 × 768 or better monitor resolution
# Mouse or tablet
Where these are the minimum specs I would recommend at least 1+gb memory and a good graphics card and a P4 or AMD processor running at 1.8ghz or better, and that would depend on how in depth you get into the program
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
511 people viewed this question
David Payne
David Payne
