Question about Rockford Fosgate Punch P3002 Car Audio Amplifier
Need to hook up two amps input and output
Do both plug in output?
  • stenco May 11, 2010
    do you need step by step instructions or is you audio equiptment malfunctioning
  • 35 Answers
No, all u got 2do is run ur rca from the output of one too the input of the other
Posted on Jul 15, 2009
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.
The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are.
The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
Dec 16, 2012 | Stanton C314 Tabletop CD and Mp3 Player
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
I have a KLH SW-90 amp. When I plug in the RCA plugs I don't get any sound to the Satelight speakers. Is this a sub amp? Do I need to hook up the high input wires to make the satelight speakers work?
I have the same amp. there a two ways to use it: The phono plug inputs are low level, are for use as an amplifier only, and their only output is the subwoofer output. In this case, any stereo satellite speakers would be driven directly from your stereo amp.
The high level inputs are meant to be driven as the same as speakers from your stereo amp. A circuit inside samples the bass and directs it to the sub amp and output. this same circut passes unamplified outputs to the satellite outputs. PM me at moestevens@cox.net if you need further info.
Oct 24, 2010 | KLH Audio Players & Recorders
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Manual
amp output goes to eq input
eq output goes to amp input
WHEN USING TAPE MONITOR on amp you run record from amp to input on eq and
output from eq to play on amp
Jul 27, 2009 | Teac EQA-120 Home Equalizer
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Rockford Fosgate Punch P3002 Car Audio Amplifier Logo
78 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
