Question about Protron PD-800 DVD Player
Screen won't appear.
I just bought a Protron DVD player PD-800 and I think I connected the DVD player to the TV correctly but I can't get the DVD player to play a DVD?
  • 10,594 Answers
2 things are important... hook up dvd player with tv through composite video or component video out terminals and second is select correct video input in tv through remote. Power up dvd player and you will see DVD Logo screen in TV. now put disc in player and press play. Let me know if need further info.
Posted on Jan 02, 2009
  • 916 Answers
Without a disk in the dvd player click setup, then hit + and - to change the region code. I don't know which code will work for you, you may have to try one by one.
  • Protron Master
  • 19,396 Answers
If you cannot see the DVD player screen ot TV start checking TV input. Select the input using the TV remote.
If still no input, then check cables at the back.
    Brigadier General:
  • 5,158 Answers
You may need to change the setting on the t.v. to dvd or aux to see it.
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
No video to my tv just the sound
Check if you do not activate by mistake the progresive scan function
Apr 23, 2009 | Protron PD-800 DVD Player
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
NO code for DVD
Dear Friends.
Do any of you think is any worht to spend a penny more on this Protron PD-800 DVD player ? I have just throught it away. I have no more time to loose.
Please just forget it. I am not a repairmen. Nice to know somebody else is capable of fix it.
Jul 27, 2008 | Protron PD-800 DVD Player
TURN OFF PROGRESSIVE SCAN PD 800
Try with this,with the disc tray empty turn on the dvd then push for 5 seconds the button stop.If this don't work connect to the tv on the video signal the y connector you got signal on black in white but you can see the menu to deactivate this function.Good luck.
May 28, 2008 | Protron PD-800 DVD Player
Will not work
Hi, you'll want the 3 colored RCA cable to hook this up to an older TV.  Yellow is for Video Out on player and Video In on TV.  Then, on player, correspond the red and white to their holes for Audio Out, and match them with Audio In on your TV.  You may have 2 spots on your TV that are labeled Audio In.  Try them both - the one that works should very close to you Video In line.
Hope that helps!
Dec 07, 2007 | Protron PD-800 DVD Player
Screen is Looping Vertically
Try to connect to s-video tv and fixit ,another is conect to pc with tv card with s-video ,select pal in the program(ejem winvcr) and you can see the picture balck and white ,is ok to fix it.
Nov 03, 2007 | Protron PD-800 DVD Player
Protron pd-007
I finally, after several months of just giving up, figured out how to get my Protron 007 DVD player to work. I hope this works for you. I have a Sanyo TV with the video controls on the front. Here are the instructions that worked for me.
1. Turn on TV
2. switch TV to video
3. Wait for "Protron" screen (Try the PSCAN button it doesn't show.)
4. Press setup and a menu will appear with 4 icons: Language, TV, a Hammer, and an Exit icon.
5. The only two icons I needed to use were TV and the Hammer.
6. TV icon: 4 choices: a) TV TYPE = choose 4.3 LB (mine was not set there); b) TV SYSTEM = NTSC; c) VIDEO = CBBS + S - video; d) DIGITAL OUT = SPDIF/RAW.
7. HAMMER icon: 4 choices: a) PARENTAL - 8; b) PASSWORD - I didn't choose one; c) ANGLE MARK: ON; d) DEFAULT: Read.
Suggestion: If that doesn't work trying playing around with the settings to see if you can get the right combination.
I hope I made your day. I know how frustrating this can be.
Jane
Oct 11, 2007 | Protron PD-007 DVD Player
PROTRON - PD-007
make sure you connected your plugs to the video you have on your tv( video1, video 2) unless you have to have it on ch 3 or 4
Jul 17, 2007 | Protron PD-800 DVD Player
On the remote control of the DVD player, just press the P-scan, reset or video SW button.. That would fix it... If you have screen kumping problem then please try this following steps... Press the setup Down arrow once Enter Down arrow 1 time Enter Up arrow 1 Enter Set up
Jul 04, 2006 | Protron PD-800 DVD Player
Protron PD-800 DVD Player Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
