Question about Dell E173FP 17" LCD Monitor
Monitor Constantly Pulses Between Black and Light Black, But Won't Display Images
Help. My Dell monitor repeatedly pulses - briefly flickers - but not long enough to see an image on the screen, while the power button just blinks green. The pulsing is constant, maybe once per second, over and over. The monitor behaves like this even when disconnected from the computer. The computer is fine and works with other monitors. In the past, I've heard a random "pop" from the monitor every so often, but never had any problems. Any advice would be greatly appreciated. Thanks
  • 4 more comments
  • Anonymous Dec 16, 2007
    I have the same exact problem.
  • ikan Dec 18, 2007
    Errr! Same exact problem. I have a hammer and I'm ready to use it!!
  • Anonymous Dec 29, 2007
    I just turn the monitor off with the switch below the screen and keep trying until it goes away.
  • Anonymous Jan 01, 2008
    EXACTLY THE SAME PROBLEM! F**K DELL!!
  • Anonymous Feb 28, 2008
    The screen is black and blinks constantly
  • Anonymous Dec 06, 2008
    monitor went off during power outage, when i powered my cpu back up, monitor wont come on. it flickers constanly but no image on screen at all. i put an old (and really big) monitor on my cpu and it works fine. i have a dell 17" flatsceen ~
  • 3 Answers
Check inverter board for bad 2sc5707 drivers...could be shorted.
Also check driver transformers for over heating symptoms...they could also be shorted.
Posted on Feb 12, 2008
I had this problem as well. To temporarily solve it, I would just unplug the power cable from the back of the monitor for about 10 seconds. When I plug it back in it would work normal, until the next startup...
Posted on Dec 11, 2008
    Novelist:
  • 138 Answers
This is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. It can be easily replaced. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 13, 2008
Contact Dell.
Posted on Jul 04, 2007
Screen black; white light pulses. Apple "genius"
It can be the power supply or the backlight inverter, worst case will be the lamp assembly.
Not easy to repair due to hard to get parts.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 26, 2011 | Apple 23" Flat-Panel TFT-LCD Cinema HD...
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Black screen with pulsing flickers of light
More likely to be capacitors failure in the power supply, worst case will be the lamps. You need to open it up and inspect the caps first, look for cap with buliging top/seal, see example of failed VIEWSONIC monitors due to bad caps (903b may be the sam as 902b): http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 21, 2010 | ViewSonic VA902B 19" LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
LiquidVideo L17LCD2 17 in. Flat Panel LCD Monitor - Power Issues
firstly stop turning it off and on because you will blow something else like a power board then it will be a big paper weight.
next get a torch and when it is powered on and supposed to be showing images, shine the torch at the screen.
if you can see everything then you have a broken backlight or problem with your backlight and connections.
they cost approx £15 and a little labour, its not a big job. you may be able to do it yourself if you can get hold of a service manual.
Feb 26, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
The monitor turns off and on repeatedly.
There is a loose connector on the cable or the cable attachment on the PC board. Jiggle the connector as its connected and see if this causes the LCD to fire up.
Sep 01, 2008 | Dell 1503FP 15" LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Monitor pulses and resets the screen on a regular basis
OJ I am fairly sure that the Power Supply is failing, try replacing ALL Electrolytic Capacitors in the Power Supply section that often "Fixes" any problems. Oh use Higer Temperature and quality ones, when doing it..
Jul 02, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
156 people viewed this question
Clive
Clive
Alun Cox
