Question about Minolta CF1501 Copier
Minolta CF1501 Duplex Unit problem
I have a Minolta CF1501.  When transporting the copier, the door to the Duplex Unit broke off.  The plastic broke so I think it would have to be replaced not repaired.  Does anyone know what to do with this? Can it be repaired?   Can I purchased just the door?   Do I need to purchase the entire Duplex Unit?  Can I bypass it and just make regular one sided copies without this door? Can I replace it with another type of door? Any suggestions would be helpful.  Thank you.
  • dlpigate Jan 03, 2009
    ok thanks ...its seems though when the door broke off it also broke the 2 plastic peg holes(hinges) on the copier that the door pegs slot into to hold it on....among a wire cable that ishanging from the copier. Maybe it isn't as bad as it looks though.
    We'll call. thanks for your help.
  • dlpigate Jan 05, 2009
    Thanks.  We tried that...where is the sensor ?  We pressed in 2 white pieces and it didn't work.   Could you discribe it.  I'll try again.
    Thanks
    Problem Solver:
  • 12 Answers
Yes you can use it without using the double sided option single only to repair need to replace door you can get a used one not so much $ call me 310-930-6348
Posted on Jan 03, 2009
  • Jessetech Jan 04, 2009
    if you don't want to buy the door or assembly trick the sensor that the door actuates.
    Good
  • Jessetech Jan 05, 2009
    the door should have a piece of plastic sticking out and going into the copier
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
Minolta 1501 errorcode COF32
Remove the black image unit and shake it so that the developer and toner inside of it is spread along the entire length of the image unit. reseat it install it correctly. if not get a new one
Sep 13, 2012 | Minolta CF1501 Copier
Como resetar tarjeta minolta cf1501
A que tarjeta te refieres????????
Si es para reiniciar los chips de las unidades de imagen ponte en contacto conmigo.
victor
victor-ipdigital@hotmail.com
Jan 07, 2011 | Minolta CF1501 Copier
My Minolta CF1501 is showing error COF 34
Before doing above open and close the front door. The code is for the Auto Toner Density Control the black image unit if it comes back after opening and closing the front door the image unit needs replacement. You can't change the developer it is all one unit. the fuser has a different code 500 series. Dont mess with gain let machine run stablize.
Dec 24, 2009 | Minolta CF1501 Copier
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
I have a Minolta cf3102 color copier. I pulled out 2 paper jams in fusing unit. Now it displays paper misfeed in duplex unit. I have checked all the paper transport way but I can not see any obstacle....
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
Mar 28, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta EP4320 - How to clear the "Cd" error code
A "CD" code means some thing is not closed correctly or attached correctly. It has been a very long time scine I worked on one, but I believe that when you added the duplex unit there is a bottom part of the duplex unit that is held on with two screws at the bottom and one shoulder screw at the top. From what I remember is that if the bottom part of the duplex unit is not flush withe copier stand and the top part of the duplex unit the joggers will not move and there is a sensor flag that get stuck in the bottom part of the duplex unit. Also, di you connect all of the connector for the unit that goes inside the copier it's self. You are dealing with a copier that is over 10 to 15 years old. Good Luck
Feb 16, 2009 | Minolta CF1501 Copier
94 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
