Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Problem for Lexmark X4270 All-in-One Multifunction Printer, Copier,...
Lexmark X8350 can't delete from Print spool
By temanalyst on Jan 02, 2009
I have the same problem since I got the Printer in June 2006 and used it with the Vista application. I have tried deleting to clear the print job from
C://Window/System 32/Spool/Printer and deleting LXM from the processor in Task Manager, and unplugging the USB and rebooting and waiting patiently.
I have tried the Lemark x 8350 from my HP, Gateway and Toshiba. It just doesn't sync up.
The only thing that does work is turning off the computer for hours and waiting for the back up to the home server to run and complete. Then turn it back on.
Lexmark should refund every one for these faulting computers. It takes more time to troubleshoot then it does working.
I agree....its unlikely this printer will ever work properly in vista.
January 2009
Solution #1
posted on Jan 26, 2009
Not Rated)
yooperbud
Rank: Wiz  Lexmark Expert
Rating: 82%, 2077 votes
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Lexmark X4270 All-in-One
Questions and Unsolved Problems for Lexmark X4270 All-in-One
Do you recommend Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax?
Answer
Answer
I would like to scan to my default Floder (such as D:/temp/scan) I can't set the value..It's default... (More)
Answer
lexmark x4270 error 1200 - followed directions for fix. didnt help. what now?
Answer
at the copy or scan output thick black line 2 cm, help to assist the problem of me...
Answer
I need to learn how to fax more than one page at a time
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
