Error code 630
My copier is giving me the above error code. Any ideas what this is? Also, the copier is telling me that a "drawer inoperable". How can I fix this? Thanks in advance for your help.
  • 1,326 Answers
Is yor copier a Copystar? Just a SWAG, you need to let us know the make and model, so the code makes a difference. There are about 18 different makes and thounds of models
Posted on Jan 05, 2009
    Problem Solver:
  • 7 Answers
Kindly let me know the Brand and Modle of your copier
Posted on Jan 03, 2009
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    We have an error code E000004-10 and the machine will not turn on.
    This is a problem with the fuser not getting hot enough. Try resetting the error code by going into service mode. Press additional functions key, then the 2 & 8 keys at the same time, then the additional functions key again. Select copier, then function, clear, then err, press OK. Power down the copier and power back on. If the error returns record the numbers after the dash. This is an important sub-code that tell you exactly what the problem is. The 0010 code says that the copier was turned of and back on without clearing the code first. The indicates that there may be a problem with the heater, DC controller, the heater power supply, or connectors on the rear of the fuser drawer. Hope this gives you some ideas of what to do.
    Feb 02, 2011 | Canon imageRUNNER 5570 Copier
    Error codes E70 and E71 appeared and won't clear
    what do E310 mean on a panasonic copier 7722
    Jul 07, 2010 | Copystar CS-1510 Copier
    I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
    Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
    Good Luck
    Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
    Copier doesn't recognize that paper is loaded
    Hello sir; Make sure you close drawer tight then pay attention on listening the noise when you close the drawer, if quiet that's mean paper lifting motor defect, otherwise go to paper sensor.
    Aug 05, 2009 | HP Office Equipment & Supplies
    Error code on Ricoh FT5733 copier
    Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
    Nov 12, 2008 | Office Equipment & Supplies
    Error code c0500
    open back coever then press reset switch from mainboard
    Sep 26, 2008 | Minolta Di2510 All-In-One Laser Printer
    Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
    Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
    Jul 22, 2008 | Dishwashers
    Minolta CF900 Photocopier
    CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
    Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
    67 people viewed this question
    jasbo
    jasbo
